Ground control coilovers for crx
Yes, they are all the same, although you can order customized spring rates. When you're ready to order or if you want more info, give me a call; numbers in the sig
Thanks for the tip i knew about the spring rates Doesn't really bother me much, it won't be Racing all the time maybe 3 times a year.How about the shock sitting in place are their any problems? Not 4 nothing but can you beat $275.00 shipped?
There are 3 kinds for CRX. Which 2 of them don't take stock shocks.
you probably want PN: 4525.1 fit agx and stock.
but got to modified the o rings.
The instructions said use o-rings and split sleeve over it then the adjustable sleeve.
There is no way the split sleeve fits.
I have to use electrical tape then O-rings to make it fit tight.
Or you could buy bigger/smaller O-rings.
EG-SIXV-TEC
13
Sep 20, 2009 09:22 AM
BrandonClaps
Nov 7, 2003 10:36 PM
