H22 into a 89 crx si?
Old Mar 19, 2005 | 04:41 AM
VegaS10's Avatar
Default H22 into a 89 crx si?
I can get a good deal locally on a full swap. Just wondering if it can be done (reasonably) and if it's worth doing.
Advantages? Disadvantages?
Thanks in advance...
Old Mar 19, 2005 | 04:42 AM
Keebler's Avatar
Default Re: H22 into a 89 crx si? (VegaS10)
Search is your friend on this one
There are MANY threads about h22 swaps
Old Mar 19, 2005 | 04:51 AM
crxnj's Avatar
Default Re: H22 into a 89 crx si? (Keebler)
Advantages-2.2litre,lots of torque,Stock block can handle 400+ hp,Motor swap can be had for around $2000..
disadvantages-no damn room,lots of money to make it fit and work,Lots of fabrication,Oil pan is low to the earth,etc
Old Mar 19, 2005 | 08:58 AM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">
Disadvantages?
custom mounts, welding.
if you dont slam the car height isnt that much of an issue, according to 2point2
search for his thread about this swap, and Private Message him about it, im sure hed be happy to share the details with you if there was something not answered in the thread itself.
Old Mar 19, 2005 | 09:40 AM
NXLude's Avatar
Supposedly enjo has already made their mounts and axles for an EF swap.....They are on their way to shelves now. ARD performance has them (the mounts) listed for around $400, they are weld in and Im not sure about the shipping situation.......So the fabrication issue is becoming less important now a days
Old Mar 20, 2005 | 02:05 PM
Mikey361's Avatar
Default Re: (NXLude)
yeah this is something ive been wondering about too. i got a b16 imn my 90 civic si and its ok but a lil tourqe wouldnt hurt my feelings at all. but wont do anything untill after i get it painted.
Old Mar 20, 2005 | 02:16 PM
NikoZai's Avatar
Default Re: (mle_92cx)
My plan is H22 with B series mounts using a B-series tranny, fabricating my own adapter plate.
Would be nice to be able to buy the adapter plate but the fools who produced it already are flakes.
Rywire.com will produce and sell these someday.
Sounds like there are some mounts on the market already but weld-in doesn't compare to bolt-in. Still some work and for most that means a shop has to do it.. and who wants to trust a shop. Most suck.
2point2 is a good contact for sure.
Old Mar 20, 2005 | 04:05 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: (NikoZai)
ill post it up again...$450 for plate that was in a running car and my own template made out of plexiglass ready to be duplictated...
[IMG][/IMG]
Old Mar 20, 2005 | 04:49 PM
dc2ITRpwr's Avatar
with a h22 swap..your car will FLY!!
Old Mar 20, 2005 | 06:37 PM
2point2's Avatar
guys,
nice to hear the h22 chatter.. but lets not do things half ***... for those plates to work properly you need very tight tolerances.
I'm sorry.. but your not going to be able to have a reliable 'conversoin' plate without having access to high-tech measuring equipment.
anytime you see two parts mate together with dowels it means that things have to be dead-nuts on. like the tranny and the head. the very reason for using dowels is for accurate location/mating of two separate parts. in this case there are three NEW surfaces being mated!
no offense to the above poster.. but to an engineer - building that plate that way is like building a house by 'eyeballing' it..
Old Mar 21, 2005 | 03:18 AM
djnikko's Avatar
Default Re: (2point2)
Whats the deal with using B series mounts to do the h22 into EF chassis swap? I read something a while ago about using spacers but havent been able to find anything more specific? Can someone provide a bit more info on this. I would like to do the swap and have almost everything to do so now but dont want to use weld in mounts if theres are some bolt on mounts available.
Your help is most appreciated
Old Mar 21, 2005 | 05:48 AM
Banned.
Default Re: (djnikko)
get some custom non billet b series motor mounts on ebay for $150 cut the bottoms off and weld on a new bottom simple!!!!
Old Mar 21, 2005 | 09:44 AM
2point2's Avatar
you will have to weld in a new chassis mount bracket for the tranny side regardless.. the shifting leavers are in the way.
Old Mar 24, 2005 | 03:00 PM
Mikey361's Avatar
it looks like i just may be going with a c5 to avoid the "custom" parts . plus less headaches.
jdm_jeners
Apr 17, 2007 09:40 PM
slitfill
Sep 27, 2005 06:25 PM
CrxSiR-GNY
32
Nov 28, 2004 04:28 PM
hgb91crx
Oct 8, 2004 04:07 PM
blackHondaB16Gen1
Sep 24, 2004 08:24 PM
