b20b wiring
Old Mar 19, 2005 | 12:44 AM
adeline's Avatar
Default b20b wiring
I am buying a b20b swap with the b20 wiring harness can I still use that 0b2 wiring harness in my crx? And how would I go about this 0b0 to 0b1 to 0b2 or what? Just trying to see what i can do to save a little time and or money.
Old Mar 19, 2005 | 12:50 AM
Beyond Imagination's Avatar
Default Re: b20b wiring (adeline)
your car at the moment is obd0. so the easiest route is to keep it as obd0 and get an obd0 dizzy and ecu. you COULD convert to obd1 which would be better so you'll need a conversion harness. odb1 ecu, dizzy, injectors.
Old Mar 19, 2005 | 12:56 AM
adeline's Avatar
Default Re: b20b wiring (Beyond Imagination)
but the b20 wiring harness is ob2 why cant i just use it
Old Mar 19, 2005 | 01:00 AM
because ripping out the entire harness out of the car is NOT something you wanna do.
Old Mar 19, 2005 | 01:02 AM
adeline's Avatar
what would I need to keep it 0b0 or 0b1
Old Mar 19, 2005 | 01:11 AM
OBD0 - 90-91 b18a dizzy and ecu
OBD1 - conversion harness for ecu and dizzy, odb1 ecu (your choice as some ecu's can be programmed for non-vtec), odb1 non vtec dizzy, obd1 injectors
Old Mar 19, 2005 | 01:13 AM
adeline's Avatar
I can use the stock injectors from a b20 and stay 0b0
Old Mar 19, 2005 | 01:16 AM
no you'll need your SI injectors and stay obd0. stock b20 injectors are obd2. considering you have an SI.
Old Mar 19, 2005 | 01:31 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">I can use the stock injectors from a b20 and stay 0b0
You can use the stock b20 injectors but you will need to remove the resistor box since those injectors are saturated..opposed to the stock peak and hold
Old Mar 19, 2005 | 01:38 AM
adeline's Avatar
Default Re: b20b wiring (Mr.speaker)
What ecu would be the best one for a obo b20
Old Mar 19, 2005 | 01:40 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline &raquo;</TD></TR><TR><TD CLASS="quote">What ecu would be the best one for a obo b20</TD></TR></TABLE>
90-91 integra..(non-obd pr4)
kylesmith3251
13
Jan 16, 2009 08:17 PM
jorDAn9
Jul 15, 2008 05:29 PM
91DroppedHatch
Feb 28, 2005 05:28 PM
1SIKCRX
Mar 27, 2004 04:43 PM
Dragger817
Jun 13, 2002 12:08 PM
