Apexi turbo timer, is this right?
Old Mar 18, 2005 | 06:06 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default Apexi turbo timer, is this right?
ok i just dropped it in and called it a night when i went to see if it worked this is what happen
when i turn the key to the 2nd acc. the tt. comes on
when i turn the key back down to 1st acc. it counts down
when i turn the key to pull it out it just turns off
i figure that the reason it turns off when i take out the key is because would have to not hook up to a constant power right?
any ways i just want to check to see if that all sound right?
turbo timer - car
blue - yellow
green - yellow/black
red - white
the only other wire in the set of 4 from the ing. is a black/white is that the constant?
Old Mar 19, 2005 | 11:56 AM
crxzcracer's Avatar
Default Re: Apexi turbo timer, is this right? (crxzcracer)
bump
Old Mar 19, 2005 | 02:03 PM
crxzcracer's Avatar
the car stays running when i turn it on acc but not if i turn it to get the key out
redh22alude
Apr 17, 2007 05:48 AM
crxzcracer
Mar 19, 2005 02:39 PM
mooook
Dec 31, 2004 12:26 PM
siis2fast
Jul 3, 2004 10:30 AM
