NEED HELP BAD!!!! SOMETHING ELECTRICAL MAYBE!!!
So i come out to mar car after work tonight and disarm my alarm and i noticed that my lights didnt flash which they usually do...but my alarm still disarmed. So then i start my car and turn on the lights, BUT then NONE of my dash lights turn on including the heating...etc
So i get out of my car and check the tailights...and they werent on...only when i push the brake pedal they come on, tried turning off/on my car a bunch of time and still nothing. And my front corner turn signal lights beside my head lights dont turn on, but my front bumper lights and rear turn signals do work when i put the signal on....
WTF is causing this????
ANYONE???THIS IS REALLY IMPORTANT???
hey buddy I'm not really sure cause I'm no expert at electronics, but this happened to me once. Your alarm? Did you install it yourself? Try checking the wires to your alarm you or someone could have done a poor job wiring the alarm and it could have shorted out the electrical system. Last year me and my buddy installed my alarm and then the same thing happened to me my dash lights, tail-lights etc. weren't working. So I took out my alarm and re-installed it. And everthing worked out fine.
there is a relay for the lights, parking lights etc, it may or most likely is this, depending on the year it should be one of the black ones up high on your fuse box under the dash, some years models etc honda acura are under the hood too. hope this helps, good luck
nope. guys it was the instrument cluster main fuse, it just blew..no biggie. As for the alarm, no i had it professionally installed like 6 months ago
SO my car is fine and everything is back to usual
BTW b18c1integra95 when u say u remove your alarm then re- installed it..did u just unplug the module, or did u completely remove all the components ie: harnesses/pins/sensors..etc??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow »</TD></TR><TR><TD CLASS="quote">nope. guys it was the instrument cluster main fuse, it just blew..no biggie. As for the alarm, no i had it professionally installed like 6 months ago
BTW b18c1integra95 when u say u remove your alarm then re- installed it..did u just unplug the module, or did u completely remove all the components ie: harnesses/pins/sensors..etc??</TD></TR></TABLE>
I removed everything the wirings sensors etc. And taped everything properly then install it agian. Everything worked again.
gwynnejd
Mar 14, 2008 04:59 PM
rodimus
Audio / Security / Video
Aug 8, 2005 06:10 AM
