ITR Oil/Water pump on JDM B16A ??
Hi HT peeps!!!
Building a 84,5mm ODB1 JDM B16A for FI...
Can i use the ITR Oilpump and ITR Waterpump on my B16A ?
Do i have to use ITR belt or B16 belt ? ITR or B16 tensioner ?
Something else i need to think about doing this ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">ITR oil and waterpumps will both work.
Timing belt should be B16 as well as the tensioner. </TD></TR></TABLE>
He's correct. Water and oil pumps are interchangeable amongst the B-series family members.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">
He's correct. Water and oil pumps are interchangeable amongst the B-series family members.</TD></TR></TABLE>
Vtec B water pumps have 22 teeth,non-vtec have 19 teeth.Obd1 and obd2 oil pumps take different timing belt covers.
The itr stuff will work on b16 with a possible timing belt cover issue depending on years of the engines.
Glenn
Glenn
