Suspension & Brakes Theory, alignment, spring rates....
Shock went through hood...still good to use?
Old Mar 18, 2005 | 11:14 AM
d_mina's Avatar
Default Shock went through hood...still good to use?
Well I've always heard about it happening but now I've become a statistic ...I was changing my oil today and saw the shock piston out past the usual....so far it made a hole on the bottom side of my hood...at least it didn't go through...question is...if i fix this...is the shock still good to use...or should I just get another one? Thanks!
UPDATE: I took the shock out and this is what I found
Modified by teameracer3 at 11:01 AM 3/19/2005
Old Mar 18, 2005 | 12:12 PM
Solracer's Avatar
Default Re: Shock went through hood...still good to use? (teameracer3)
This is not a "normal" occurance, did you have you shocks install recently? Sounds like someone forgot a washer. This shocl should be fine, but you need to take the front suspension apart and make sure that the washer that goes on top of the shock but under the bushings is there.
Old Mar 18, 2005 | 12:47 PM
CRX Lee's Avatar
Somebody forgot the load bearing washer that sits under the bottom rubber (and above the bump rubber) and holds everything together at the mount. You would think that the fact that the top nut never really tightened down might have been a clue that something was amiss. They also turned the top washer upside as well. You will probably be fine reinstalling them and I'd thing the car would be better with a functioning damper this time.
Old Mar 18, 2005 | 12:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Shock went through hood...still good to use? (Solracer)
Obviously it isn't in place. Who the hell isntalled those? You better make sure all 3 of the other ones have the hardware in place. Thats a total bone head manuver if a shop did that. I would make those ******* buy you a new hood!!! If you did this yourself, how could you **** it up if you've "Hear of this happening before". This is an installation error. You have monkeys workin' on your car...
Anyways, the shock will be fine, but your gonna need some good OEM hardware to replace the missing/damaged bushing seat...
Also looks like your UCAs are hitting your shock tower...
Old Mar 18, 2005 | 08:48 PM
kenversusryu's Avatar
if they start leaking, that's a good sign that they're bad.
Old Mar 18, 2005 | 09:38 PM
mckenzie's Avatar
its just the washer..get the oem ones which are cheap and bigger than reg. washers
Old Mar 18, 2005 | 10:28 PM
d_mina's Avatar
Default Re: Shock went through hood...still good to use? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Obviously it isn't in place. Who the hell isntalled those? You better make sure all 3 of the other ones have the hardware in place. Thats a total bone head manuver if a shop did that. I would make those ******* buy you a new hood!!! If you did this yourself, how could you **** it up if you've "Hear of this happening before". This is an installation error. You have monkeys workin' on your car...
Also looks like your UCAs are hitting your shock tower... </TD></TR></TABLE>
UCA's?
Old Mar 19, 2005 | 12:09 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teameracer3 &raquo;</TD></TR><TR><TD CLASS="quote">
UCA's?</TD></TR></TABLE>
Upper Control Arm
Old Mar 19, 2005 | 09:57 AM
d_mina's Avatar
Default Re: Shock went through hood...still good to use? (FunctionMotoring)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunctionMotoring &raquo;</TD></TR><TR><TD CLASS="quote">
Upper Control Arm</TD></TR></TABLE>
ohh hah sorry..i thought he was referring to something in the engine bay...why would my UCA's be contacting my shock tower like it does...my car is not that low?
Old Mar 19, 2005 | 12:09 PM
DsITR's Avatar
ohh hah sorry..i thought he was referring to something in the engine bay...why would my UCA's be contacting my shock tower like it does...my car is not that low?</TD></TR></TABLE>
Do you have a camber kit? ie Skunk 2 UCA style?
Alot of people have had trouble w/those hitting the shock tower.
Old Mar 19, 2005 | 04:25 PM
d_mina's Avatar
I do have a camber kit...I'm not sure what kind though...it was installed on the car when I had purchased it.
MRdc4
May 30, 2006 09:21 PM
The Maniac
10
Jan 16, 2006 03:29 PM
d_mina
Mar 18, 2005 01:10 PM
ILOVEGIRLS
Apr 17, 2002 04:57 PM
