b20 knuckles
ok I am doing a b20 in a ef with the b16 tranny the cable ...one ... will the acura axles fit the stock si ef knuckle???? woundering ...if you have any info ..hit me up ...oh ...and if any one has a si tranny 89-91 no grinds .. hit me up
Miek ~beyond label~
also ..I was woundering .... what computer u can use with the b20 .. can u use a ls ...... or do u have to get the b20 computer
Miek ~beyond label~
Its a tight squeeze but they will fit. One of my best friends has a B16 with a Y1 tranny in his EF and it fit fine. The only concern I would have would be the B16 tranny it has a higher gear ratio than what the B20 motor is accustomed to running at. I've heard B16 Tranny's on B20's will cause them to Pop pretty quick. Besides you'd get better results out of an LS or GSR tranny. I have a B20 in an EG hatch and I have an LS tranny It will handle all the torque you can throw at it and in a B20 thats just about all you got to work with. Also the LS computer will work just fine I have a p75 in mine and the fuel mapping is so close to the stock b20 computer that it really runs the motor well. Good Luck
The b16 cable trans will be fine for the b20. You can use the stock hubs and 90-93 integra axles. You can also use the Pr4(Ls) OBD0 ecu as all the electronics are OBD0 or you can convert to OBD1 and run a b series non-vtec ecu.
