Ecu Crap
So i get in my car and find that my Manitence Required (not the check engine light) light is flashing. doh. It flashed 10 short times. 10 IAT - intake air temperature sensor correct? I just wanted to make sure on this... my Check engine light <U>WASNT</U> blinking.
Also, when I jumped the service indicator my abs code flashed a 4 8 wheel sensor LR. Now when the car is started the ABS light <U>isnt </U>on. Any ideas?
Normally i wouldnt have posted this but it seems kinda odd. maybe im just a noob
Maintenance Required Light should not be confused with your CEL. The Maint light comes on every 7500 miles exactly, to remind you to change your oil and do the preset service schedule. In order to reset it, just grope around under the dash in front of your right knee. You should feel a button (square) underneath that cover panel - press it, hold it down, and turn your ignition to Access/On, I can't remember. Keep holding it, and the light will go off.
Red2001GSR
Feb 19, 2002 10:28 PM
