OBD problems
Old Mar 18, 2005 | 10:02 AM
ebp_dc2's Avatar
Default OBD problems
Ok so heres the deal...i got a 98 integra with a 95 h22. In other words obd2 to obd1 conversion. I have to have OBD 2 for my car to pass inspection in NY. I recently purchased an obd2 complete head with distributor and IM, and ECU. What are the exact differences b/w obd1 and obd2, and how would i go about converting to obd2 with the parts that i have??? If i swap the entire head setup, can i just plug and play the obd2 ecu. I also have a locash obd 1 to obd2 adapter which eliminates the second o2 sensor. Any help would be greatly apreciated cuz i plan on doing the swap this weekend
Old Mar 18, 2005 | 11:39 AM
ebp_dc2's Avatar
Default Re: OBD problems (h22d dc2)
up for some help
Old Mar 18, 2005 | 11:43 AM
b204dr's Avatar
should just be able to plug in ecu and go with check engine light - dont know how strict emissions is their , if not to bad bung seconday o2 (fwih)
Old Mar 18, 2005 | 02:19 PM
ebp_dc2's Avatar
unfortunely they can't pass you unless u have no check engine lights. SOMEONE answer my question as to the sensors, etc
Old Mar 20, 2005 | 06:16 PM
IROSOLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22d dc2 &raquo;</TD></TR><TR><TD CLASS="quote">unfortunely they can't pass you unless u have no check engine lights. SOMEONE answer my question as to the sensors, etc</TD></TR></TABLE>
obdII had more sensors then OBDI. what you need is a OBDII to a ONDI converter. Cost like 75.00. and that eliminates all secondary sensors on the OBDII harness.
Old Mar 20, 2005 | 06:36 PM
ebp_dc2's Avatar
ok i know it has more sensors but i want my car to be obd2 again, and i have the necessary parts as far as i know...what i need to know is where the sesnors are in the engine!
Old Mar 20, 2005 | 07:33 PM
Dragline's Avatar
Your OBDII ecu is going to need a crank angle sensor,which you don't have on the OBDI motor so your going to have to wire it back to the dist. and it will eliminate the CEL for that sensor.
For the O2 sensor if you have a adapter for that and it works use it.
As for you saying you have a OBDII head why do you need that,Just use your dist. thats on there now and ethier repin the plugs or buy an adapter for that to.
Old Mar 21, 2005 | 06:09 AM
JimBlake's Avatar
Default Re: OBD problems (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Your OBDII ecu is going to need a crank angle sensor,which you don't have on the OBDI motor so your going to have to wire it back to the dist. and it will eliminate the CEL for that sensor.</TD></TR></TABLE>You're probably talking about the crank FLUCTUATION sensor. That's on the oil pump, behind the timing belt. You'll need an OBD-2 oil pump, & the CKF sensor. Maybe trim your lower timing cover to make it fit, or get an OBD-2 lower cover.
Old Mar 21, 2005 | 06:43 AM
ebp_dc2's Avatar
hmmmm now that is a problem... any other sensors i should know about...
Old Mar 21, 2005 | 08:28 AM
Dragline's Avatar
Default Re: OBD problems (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">You're probably talking about the crank FLUCTUATION sensor. That's on the oil pump, behind the timing belt. You'll need an OBD-2 oil pump, & the CKF sensor. Maybe trim your lower timing cover to make it fit, or get an OBD-2 lower cover.
You don't need the oil pump and a CKF sensor,you can just wire the 2 wires back to your OBDI dist. and it will run the same and no CEL.
If needed I can tell you how to do it,just IM me.
Old Mar 21, 2005 | 04:52 PM
ebp_dc2's Avatar
up for some more help on this topic
Brugalontherocks
Apr 28, 2008 08:10 PM
turbogsr18
Apr 28, 2008 10:37 AM
DarkBB4
Mar 27, 2005 09:56 AM
ebp_dc2
Mar 18, 2005 10:01 AM
S4gasm
Oct 30, 2004 12:05 PM
