rear sway bar?
i was wondering if i can take off the rear sway bar? my lower control arm is back and i was planning to put on 93 rear lower control arms. the 93 LCA don't have a place for the sway bar. will it be ok? thanks
What's the difference between your rear LCA's and the ones you are putting on?
Are yours broken or something?
No upgrade found here.... in fact, you are downgrading.
You are loosing the sway.
You are about to gain some understeer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sonicrex »</TD></TR><TR><TD CLASS="quote">
Why not find some LCA's that are equipped to handle a sway bar?</TD></TR></TABLE>
That's a much better idea.
Mikes2000civicsi
Mar 27, 2008 09:02 PM
