b16a2 Need more Torque
Old Mar 18, 2005 | 06:20 AM
cbabyby's Avatar
Default b16a2 Need more Torque
does anyone know what i can do to increase my torque equal to or above a gsr without buying a supercharger or a turbo.
Old Mar 18, 2005 | 07:57 AM
NJIN BUILDR's Avatar
Default Re: b16a2 Need more Torque (cbabyby)
Here you go. https://honda-tech.com/zerothread?id=951003
Glenn
Old Mar 19, 2005 | 03:49 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbabyby &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what i can do to increase my torque equal to or above a gsr without buying a supercharger or a turbo. </TD></TR></TABLE>
Increase displacement. If you get a B17A crank and resleeve to 84mm, you will have a displacement greater than a GSR (with a better rod ratio, to boot). And while you are at it, get higher compression pistons. Compression will increase torque as well. Just remember to select your compression ratio in accordance to whatever fuel you plan to use or which is available where you live.
95accord8966
Dec 16, 2007 01:29 AM
OSIRIuS23
Jan 23, 2006 01:34 PM
philly91crx
Sep 28, 2005 10:06 PM
Aar99GSR
Mar 20, 2002 01:31 PM
blazin
Nov 26, 2001 12:57 PM
