I want to Learn to PnP....
Old Mar 17, 2005 | 07:54 PM
MugenB16A2's Avatar
Default I want to Learn to PnP....
My Machine Shop gave me a "Bum" head to practice on....
He said if it looks like ****, Hit it with a hammer, it's no good anyways, Just for practice...
I have a basic Home Depot DREMEL kit that I've had for a while, but want to learn the "BASICS" of just cleaning up the Ports on OEM heads....
ie - The NEW ITR heads.... Those HORRIBLE PnP jobs done by Honda and the casting "Ribs" if you will in the middle of the ports....
Can anyone give me ideas of "techniques" or proper DREMEL bits to buy at Home Depot to just hack away at the Practice Head, b/c I don't want to **** up a BRAND NEW ITR Head....
Thanks...
-George
Old Mar 17, 2005 | 08:33 PM
teggytegteg's Avatar
Default Re: I want to Learn to PnP.... (MugenB16A2)
yeah i wanna know to...bumpppers
Old Mar 17, 2005 | 09:04 PM
EG6R's Avatar
This is what i got: https://honda-tech.com/zerothread?id=1176733
Old Mar 17, 2005 | 10:31 PM
MugenB16A2's Avatar
Here's what I've done so far....
Again, I have NEVER done this before, nor do I have many bits for my dremel to properly get this done...
But, here goes... Please bear with me... It is 2:20am and I just finished...
Nice little comparisson between Stock port (Left) and My handy work (Right)
Another comparisson with the Flash...
Stock Port vvv
Clean Port vvv
Shedding some Light onto the Subject...
Can you spot which one is My handy work???
How about Now???
<FONT SIZE="3">Constructive Criticism/suggestions are appreciated... As I am wanting to further my knowledge, but Please, keep RUDE comments to yourselves or PMs....</FONT>
Modified by MugenB16A2 at 3:16 AM 3/18/2005
Old Mar 17, 2005 | 10:39 PM
hey bro which of the bits did u use? i got pink colored bits with my dremel...are those the ones i use?
Old Mar 17, 2005 | 10:47 PM
MugenB16A2's Avatar
Default Re: I want to Learn to PnP.... (teggytegteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggytegteg &raquo;</TD></TR><TR><TD CLASS="quote">hey bro which of the bits did u use? i got pink colored bits with my dremel...are those the ones i use?</TD></TR></TABLE>
Nah, It's a Brown "Sleeve" that goes over the Rubber Cylindrical attachment that you tighten and it expands to hold onto the sleeve.... They are kind of Gritty adn I had to go easy for a while till they got worn, then I could speed it up a LITTLE... VERY LITTLE.. then I smoothed everything out...
I'll try to find a pic of the attachment...
Old Mar 17, 2005 | 10:50 PM
MugenB16A2's Avatar
Here ya go...
in the pic it is the VERY top attachment above the last cutting disc....
The screw atop of it by tightening expands the rubber cylinder enabling it to "Grab Hold" of the Grinding Sleeve....
I had like 4 sleeves....
Old Mar 18, 2005 | 02:20 AM
kidkombo's Avatar
Default Re: (MugenB16A2)
carbide bit?
Old Mar 18, 2005 | 07:18 AM
MugenB16A2's Avatar
Default Re: (kidkombo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo &raquo;</TD></TR><TR><TD CLASS="quote">carbide bit?</TD></TR></TABLE>
Not really sure... LoL... I'd bet not...
Old Mar 18, 2005 | 12:47 PM
C M S's Avatar
Try Summit and Jegs, they offer some descent porting kits....
p3lon21's Avatar
I work in a machine shop I try dat. all it do is to take the dirt off an look polish. I use another tool dat spins I put a grinding wheel a small one and Is 100x faster.I dit the same with my intake. It runs better. I measured the head and intake. the intake hole is way smaller. Soon I will cut the intake to be the same as the head.
Old Mar 18, 2005 | 10:53 PM
MugenB16A2's Avatar
So, I got a couple more bits from HD today and I went a little further into the Ports...
I got 60 GRIT sleeves to grind away the casting material, and 120 GRIT to smooth them up a little bit better, and once achieving a nice smooth even surface, I went with an Aluminum polishing Brush...
They are DEFINITELY much smoother than OEM castings, but without a Flowbench, there is no telling whether or not I did any good...
But from the Eye, and Touch, it seems to be an improvement on OEM casting ports....
My only problem areas were where the Valve guide comes out into the ports... I cannot seem to figure out HOW to get the Dremel into that tight area...
Any suggestions or Tips from the Gurus; (Rocket, Max_CFM, Big Teggie)...
Thanks...
jeff652
Jul 22, 2009 09:16 AM
ITR_HO
Dec 30, 2006 01:45 PM
ITRFetish2000
May 24, 2004 02:40 PM
xsnrgsr
Aug 22, 2003 04:43 PM
spoonfed95
Mar 24, 2003 09:33 PM
