WANT TO BUY RC INJECTORS, BUT?
I have a 1998 jdm itr motor, running a chipped P 28 ECU (obd1 program), in a 1993 delSol. What injectors do I have saturated or peak and hold? I suppose the injectors that I have in there are for a OBD2?? Please help me out here, I got to order my 310cc from RC and dont know what I should order!!!
Thanks all!!!
Thanks all!!!The injectors off the 98 Type-R is a saturated injector (OBDII). If the engine is stock or mildly modified, the factory injectors should be OK. You would want to use the 310cc injector for a modified motor running aggresive cams.
Thank you!! My only question now is 310's enough for 200-220 WHP? I really dont want to run the injectors higher than 80% duty cycle at 50psi if I can.
He is RCs injector size worksheet. http://www.rceng.com/technical.htm#WORKSHEET
Glenn
Glenn
