TPS sensor help
Old Jan 24, 2002 | 07:40 AM
stizzit's Avatar
Default TPS sensor help
Can anyone tell me the symptoms of a bad TPS sensor? My car recently started actin' up. The car will start and warm up at 3500rpm and then slowly decrease to 2krpm as the cold start valve warms up. Unfortunatly it never goes below 2krpm. We unplugged the TPS and nothing happened even while opening the throttle. Any help would be greatly appreciated, tia.
Old Jan 24, 2002 | 08:01 AM
rainforest's Avatar
Default Re: TPS sensor help (stizzit)
your car reving by its own. running extreamly rich, throwing a code 6. you can check it out by running a multimeter to the tps you should be around 4.5-4.7 at wot from what i rember.
Old Jan 24, 2002 | 08:30 AM
garagespecial
Guest
Posts: n/a
Default Re: TPS sensor help (rainforest)
how would you fix that problem? my car is reving on its own?
pleej
Oct 14, 2009 10:25 AM
deucedeuceEK
Apr 27, 2007 02:39 PM
shutta
Apr 5, 2007 04:46 AM
