H22 swap done but not working please HELP
Old Mar 17, 2005 | 04:10 PM
95accordh22a's Avatar
Default H22 swap done but not working please HELP
well lets start with the basics
95 accord EX with JDM H22 swap, jdm p13 ecu
go to start it up and its not starting, gettin spark and fuel still no start up
just the header is on and the ecu is good, it does like make a backfirin noise but thats it
Old Mar 17, 2005 | 05:10 PM
nslude's Avatar
Default Re: H22 swap done but not working please HELP (95accordh22a)
are you sure its timed up at TDC?
Old Mar 17, 2005 | 05:16 PM
Default Re: H22 swap done but not working please HELP (nslude)
thats what i was gonna check tomorrow morning, cause im pretty sure everything was on time considering that the belt was on when i got it but i dont know, ill deff check that tomorrow , can it be anything else???
Old Mar 17, 2005 | 05:18 PM
also is the firing order the same for the h22 as on my stock accord?
Old Mar 17, 2005 | 05:26 PM
95PreludeSi's Avatar
should be the same.... 1 3 4 2
Old Mar 17, 2005 | 05:30 PM
Default Re: H22 swap done but not working please HELP (95PreludeSi)
does anyone know if i can tell the difference between obd1 h22 injectors and ob2 injectors??
Old Mar 17, 2005 | 05:40 PM
Boost3d22's Avatar
the obd2 is highimpedence high resitance, 12-16 ohm i believe.... the obd1 injectors are peak and hold i believe so test them with a multimeter
Old Mar 17, 2005 | 06:31 PM
BB4's Avatar
BB4
check to make sure your spark plugs wires are plugged into the right places on the dist.
should be :
...3...
1.....4
...2...
when looking at the dizzy i believe
Mudyota91
Oct 5, 2013 07:39 PM
4DRPIMPIN
Feb 12, 2005 06:27 AM
spettinger
May 18, 2004 03:44 PM
