i had to change my front left caliper, whats the easiest way to bleed that thing the right way?
Old Jan 24, 2002 | 06:37 AM
chuckd05's Avatar
New User
Default i had to change my front left caliper, whats the easiest way to bleed that thing the right way?
whats the easiest and best way to bleed the one caliper, i heard u dont need to do all 4 if u only take one off, let me know! thanks
Old Jan 24, 2002 | 06:54 AM
samagon's Avatar
Default Re: i had to change my front left caliper, whats the easiest way to bleed that thing the right way?
there is the bleed screw on the back of the caliper that you have to use one of those special line wrenches for, attach a clear piece of hose to it so that you can see the fluid and any bubbles. and have it drain into an old container so that you don't leak all over your driveway.
have a friend sit in the drivers seat and pump the brakes till they don't go down and hold them. then you, using the line wrench, open the bleed screw just enough for a little fluid to come out. repeat process until all air is out of the system, checking periodically to make sure the resevior is topped off (it would be bad to run out of fluid in the resevoir as you would then have to bleed the whole system). this whole process should take you about 15-30 minutes depending on how much air is actually in the system.
the soL that could
Dec 3, 2011 09:31 PM
munky69
Suspension & Brakes
Mar 30, 2010 04:17 PM
budomove
10
Oct 26, 2007 03:18 PM
eltigre
22
Jun 27, 2006 12:51 PM
extrmeboost
Apr 9, 2003 01:00 AM
