installing a H22 ?
Old Mar 17, 2005 | 10:46 AM
1SiKDA8's Avatar
Default installing a H22 ?
hey, i'm puttin a H22 in my 92 DA8, i no its unusual but i'm wondering if ne1 knows how much time/$$$ it wud take to make the motor mounts. r does ne1 no of a good shop around in the midwest??
Old Mar 17, 2005 | 03:57 PM
skunked's Avatar
Default Re: installing a H22 ? (1SiKDA8)
I bought a brand new set of HCP for $200. That's pretty cheap and they work great.
Old Mar 18, 2005 | 08:01 AM
1SiKDA8's Avatar
Default Re: installing a H22 ? (skunked)
you must have a 94 r newer integra. puttin it in my 92 is alot more complicated, since the company who did make the mounts went out of business, and now you have to cut & weld the **** 2gether. fabricatin' my own MM is gunna suk, i was just hopin' their was an easier way sum1 did it.
Old Mar 18, 2005 | 08:05 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKDA8 &raquo;</TD></TR><TR><TD CLASS="quote">you must have a 94 r newer integra. puttin it in my 92 is alot more complicated, since the company who did make the mounts went out of business, and now you have to cut & weld the **** 2gether. fabricatin' my own MM is gunna suk, i was just hopin' their was an easier way sum1 did it. </TD></TR></TABLE>
IC, that does suck. Nobody else makes the mounts?
Old Mar 18, 2005 | 08:27 AM
1SiKDA8's Avatar
not that I'm aware of. I've searched hi and lo on the net and through import shops. everyone says its a bad idea but f* that. I've heard of people doin it, but I've never seen it personaly, i just want sumthin different. this trial user **** suks, i can only post 5 times a day
Old Mar 18, 2005 | 08:29 AM
skunked's Avatar
I know they make them for the EF....aren't they very similar? I know I have seen H22's in DA's.
Old Mar 18, 2005 | 09:31 AM
WH0R3nEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKDA8 &raquo;</TD></TR><TR><TD CLASS="quote">not that I'm aware of. I've searched hi and lo on the net and through import shops. everyone says its a bad idea but f* that. I've heard of people doin it, but I've never seen it personaly, i just want sumthin different. this trial user **** suks, i can only post 5 times a day </TD></TR></TABLE>
You can check that HCP place that the other dude told you about, but Im pretty sure the only place that makes the mounts are place racing. placeracing.com
Their site is down right now, so you'll have to wait. Im pretty sure no matter what mounts you get, you'll still have to do some cutting and myabe some welding. It will fit, but it'll take some time. I'd say, call up RS motors out of burnsville, MN and see how much they charge for the motor and the install. They do good work and most likely wont try to talk you out of what you want. Their number is 952-707-0100. Good luck!
Old Mar 18, 2005 | 09:32 AM
WH0R3nEF9's Avatar
Default Re: installing a H22 ? (1SiKTeG)
i dont know how to put a link on, let me try that again. If this doesnt work, sorry.
Placeracing.com
Old Mar 18, 2005 | 09:33 AM
WH0R3nEF9's Avatar
one more time!! http://placeracing.com
turbogsr18
Mar 19, 2008 08:18 AM
Noemotion_91DA
Aug 1, 2006 02:53 PM
85
Welding / Fabrication
11
May 23, 2005 11:57 AM
509MTRS
Apr 5, 2004 07:56 PM
