1994 EX/LX exhaust manifold swap, o2 sensors different?
Old Mar 17, 2005 | 06:04 AM
Mike813's Avatar
Default 1994 EX/LX exhaust manifold swap, o2 sensors different?
i was just curious since my car has been getting bad gas mileage forever even after most major tuneups...
ive done a ex exhaust manifold on my lx engine, and i never changed out the LX's o2 sensor to a EX o2,,, ive checked part #'s and they do differ in part #'s but is there any real difference in the EX/LX o2's besides a longer wire?? im thinking the o2 difference is my culprit for my gas mileage... if anyone has anymore info thatll be great! thanks.
Old Mar 17, 2005 | 12:28 PM
Intense3.2's Avatar
Default Re: 1994 EX/LX exhaust manifold swap, o2 sensors different? (Mike813)
well if you just swapped the manifold then you shouldnt have to swap the o2 sensor... did this problem start when you swapped the manifold>? are you sure there is no exhaust leaking anywhere? btw, why did you do this?
Old Mar 17, 2005 | 03:17 PM
Mike813's Avatar
Default Re: 1994 EX/LX exhaust manifold swap, o2 sensors different? (Intense2.2)
i swapped the manifold because i wanted the 4-2-1 instead of a 4-1 said to have a little better low end speed (daily driven), the manifold did not come with a o2, so i reused my old o2 from my lx, but on diagrams off hondaautomotive the 2 o2 part #'s are different... from the looks of the genuine ones the wiring is just slightly longer, but im not sure if voltage or anything else might be different causing a wrong reading or something. but with the leaks ill have to double check on that next time when i have a day off
and my car has started getting bad mileage since the exhaust, but i removed the straight thru oem piping and got a maze design back pressured muffler... i was hoping itll improve a little but still pretty similar mileage... tune up was done recently but o2 was not changed... the o2 has about 40-50k on it only...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 &raquo;</TD></TR><TR><TD CLASS="quote">well if you just swapped the manifold then you shouldnt have to swap the o2 sensor... did this problem start when you swapped the manifold&gt;? are you sure there is no exhaust leaking anywhere? btw, why did you do this?</TD></TR></TABLE>
Old Mar 17, 2005 | 03:43 PM
Intense3.2's Avatar
well its obvious now... the header is causing it...
Old Mar 17, 2005 | 03:49 PM
Mike813's Avatar
imma try getting new gaskets and stuff for the ex. manifold first i guess,,, bout to just sell this thing and get a hybrid
Angela Thomas
Jul 21, 2017 09:45 AM
alotawatts
Sep 20, 2004 03:24 PM
4thgen92accord
Jul 20, 2004 10:06 PM
