Some problems with my car.
From: With my POS D15B2, Whereever whenever, United States
I have a 93 cx hatch.
My srs light is always on?
I changed to a SI cluster, and now my signals don't turn on?
that is all
thanks
also my antenna end broke, is there an easy way to replacing it?
thanks
that is all
thanks
thanks
srs problems usually occur when car has been hit- submerged in water etc- fixing it can be spendy
changing cluster and having signal not work sounds like a wiring issue - try the other cluster if they work then - wiring for sure-
antena - buy aftermarket simply to change !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">antena - buy aftermarket simply to change ! </TD></TR></TABLE>
crutchfield has a wide selection for cheap - - and yes - - you could swap the antenna with one arm behind your back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">Also how to take the steering wheel off an eg
thanks</TD></TR></TABLE>
chilton's, chilton's, chilton's...
im sure u did but jic... did you try searching?
9.3.S.I.L.U.D.E.
18
Aug 20, 2009 01:50 AM
Manolo
Dec 28, 2005 05:20 PM
JRizEJ6
Dec 3, 2005 01:22 PM
