*Question regarding positioning of clutch cable*
Old Mar 17, 2005 | 04:29 AM
Fred n J_v2.0's Avatar
Default *Question regarding positioning of clutch cable*
I was wondering if anyone had a spare moment, could they take some pictures of how the clutch cable enters the engine bay, and how the clutch cable enters the pedal assembly? I am looking at the helms manual and its not too clear.
In the process of an auto-to-manual swap and I just want to make sure I will be making the hole in the right spot.
The car is an 88 civic hatchback, if that makes any difference.
TIA,
j
Modified by Fred n J's_1.8's at 5:08 PM 3/18/2005
Old Mar 17, 2005 | 12:30 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: *Question regarding positioning of clutch cable* (Fred n J's_1.8's)
Since you asked nicely:
Goes through the hole in the center of pic:
http://img18.exs.cx/img18/782/cable0012to.jpg
http://img18.exs.cx/img18/9602/cable0020xz.jpg
http://img18.exs.cx/img18/4869/cable0039hd.jpg
http://img18.exs.cx/img18/640/cable0050sy.jpg
Modified by 88DXCRX at 4:47 PM 3/18/2005
Old Mar 17, 2005 | 03:30 PM
88DXCRX's Avatar
Default Re: *Question regarding positioning of clutch cable* (88DXCRX)
http://i152.exs.cx/img152/8867/cable0011xa.jpg
http://i152.exs.cx/img152/5571/cable0025ws.jpg
http://img173.exs.cx/img173/660/cable0031nh.jpg
Modified by 88DXCRX at 4:48 PM 3/18/2005
Old Mar 17, 2005 | 03:46 PM
88DXCRX's Avatar
Its hard to get a good shot of the inside...
http://img198.exs.cx/img198/853/cable0070ig.jpg
http://img198.exs.cx/img198/2334/cable0095bv.jpg
Old Mar 17, 2005 | 03:53 PM
Thanks a ton man... I appreciate all your help.
Old Mar 17, 2005 | 04:01 PM
88DXCRX's Avatar
Here is a link that might help:
http://hometown.aol.com/jrmupzaii/auto2man.html
I pm-ed a guy who has done this and
he said there was a hole there already..
Probably has a rubber plug in it...Does yours have a hole there?
Old Mar 17, 2005 | 04:15 PM
This is my car...
underneath the hood:
by the pedal assembly, i think thats the rubber plug that you are referring to.
looking at this pic here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
by that hole, i see two spot welds that are also there on my car. I guess I just drill http://is.rely.net/1-870-14340...there and pass the cable thru the rubber plug?
Modified by Fred n J's_1.8's at 5:23 PM 3/18/2005
Old Mar 17, 2005 | 04:35 PM
88DXCRX's Avatar
Yours looks just a little different...
Those are all '88 CRXs btw so your results might vary..
You basically will want it to be in a straight line with the
point it attaches to the clutch pedal.. as straight as possible..
Man..Good Luck, Maybe someone with the same model will post up.
Old Mar 17, 2005 | 05:14 PM
doh*
Thanks for your help man... if anyone who has done a conversion in a hatch before, please feel free to post up your experiences...
thanks again
Old Mar 17, 2005 | 05:21 PM
RCautoworks's Avatar
Can you take a pic but a little farther away.
I have done a conversion on a 1990 crx, and to my knowledge all cars that are auto should already have the hole on the firewall. Honda made it like this to save money and time.
I really hate to think your gonna have to drill a hole because the spot is so tight, I can't imagine what you can get in that space, plus the firewall is not easy to drill threw.
Old Mar 17, 2005 | 05:27 PM
91_HB's Avatar
I just converted my 91 hb into a manual. the pics 88dxcrx sent u of where the plug is are right. My car had the plug in the came place as his pics. from looking at yur pics yur car is quiet a bit different under the hood than mine r u sure its not an 87? but anyways id try poping the plug that is pictured in your first pic and c if that works. I strongly recomend using 88dxcrx webpage http://hometown.aol.com/jrmupzaii/auto2man.html as a guide to help u along the conversion. I know it saved my when it came to the wiring .
Good luck and I hope u have as much fun as i did when changingn the pedals lol
Old Mar 17, 2005 | 05:41 PM
Default Re: *Question regarding positioning of clutch cable* (91_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_HB &raquo;</TD></TR><TR><TD CLASS="quote"> r u sure its not an 87? </TD></TR></TABLE>
yeah, i know my car is an 88. its what i said in the first post of this thread.
the car may look different to some of you because it is stripped. there are no fuel lines, currently no pedals, no harness etc...
Here are some further away pictures of inside the car as well as under the hood.
Thanks
Click on the pics for bigger pics...
Underneath the hood
Old Mar 17, 2005 | 06:00 PM
88DXCRX's Avatar
You are here-by known as the man with "No hole..."
You have the dash out? looks like...
I would bolt up the pedals and use a straight edge to pin-point a place to drill..
Old Mar 17, 2005 | 06:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">You are here-by known as the man with "No hole..."
I would bolt up the pedals and use a straight edge to pin-point a place to drill..</TD></TR></TABLE>
lol...i'll keep you guys updated as to how this turns out
Old Mar 17, 2005 | 06:25 PM
88DXCRX's Avatar
A little more "food for thought.."
Looking at the pic of the white car,there is a tube or tunnel
between the inner and outer firewall sheet metal
which the cable goes through..
I would imagine this also serves as a reinforcement to keep
the firewall from flexing when you push down on the clutch pedal..
In addition to making the hole for the cable to pass through,
You might consider some sort of reinforcement between the
inner and outer firewall or some external bracing or bracket in the engine bay..
follow what I am saying?
Old Mar 18, 2005 | 04:01 AM
91_HB's Avatar
Did u trying looking from the inside? It shuld be really easy to spot from the inside its just above and to the clutch pedal. Id take a pic but i dont have a digital camera. If its not there then I guess [QUOTE=88DXCRX]You are here-by known as the man with "No hole..."
Good luck
Old Mar 18, 2005 | 01:08 PM
*UPDATE*
Installed the pedal set today.
Inside the car by pedal assembly:
Underneath the hood:
Hopefully, it will hold up ok... Still wish I could see comparable pics from hatchback owners...
Old Mar 18, 2005 | 02:06 PM
88DXCRX's Avatar
Looks good...
If you do get any flex in the firewall,
You could probably fasten the cable down to the shock tower
with a bolt and a cable clamp something like this:
Old Mar 18, 2005 | 05:58 PM
Doing the same thing but on a 94 civic, I already did one on my car. Just glad I got the pedals out.
Old Aug 17, 2007 | 05:20 PM
KrenzyRyan's Avatar
Default Re: *Question regarding positioning of clutch cable* (RCautoworks)
K, I didn't want to have to post my own thread, but could someone please please post a picture of what this mount looks like:
I cannot find it anywhere after I took changed my cam seal urg!!
Old Aug 17, 2007 | 09:03 PM
I CRX I's Avatar
uhmm, why? does this have anything to due with the original post topic?
soon2befast
May 29, 2021 05:53 AM
jonnyt1130
10
Jun 1, 2010 09:51 PM
90_civic_Si
Nov 6, 2006 06:51 AM
cm zak
Feb 7, 2006 09:54 AM
