CTR in a eg coupe?
OK so i put the ctr engine in my 95 civic coupe. Thing is i used the mounts that came on the engine which are the same mounts the 99-00 si used. Now the engine is mounted in there with the mounts but it sits a little high. Other than sitting a little high (which gives me more ground clearance) i don't see any other issues. Would i have problems leaving it like this and driving it hard?
The axles don't seem to be out of alignment as far as i can tell.
Does anyone foresee any problems i may have down the road by not using the right mounts. I have the integra mounts that i need (just picked up today) the drivers side mount doesn't fit the mounting point on the engine. I tried to get the current rear mount out but i gave up and just mounted it back the way it was.
Is there something i'm missing here? Am i safe to just leave it the way it is? Anyone else ever done a b-series swap using those mounts in an eg?
i think when he said "EG" it was more 92-95 style civic, coupe which is ej1\2 depending on trim i beleive regardless,
Theres been tons of people to do swaps, so some pictures if possible may help for that peace of mind if your unsure of things. good luck
i do plan on running p/s i just need either a new p/s pump or a new line. The d series p/s pump doesn't match up with the b-series brackets and the b-series p/s pump that came with motor doesn't match up with my lines.
For now i'm just letting it bolt to that mount to keep it secure and keep the lines plugged.
out of curiosity why would the ctr motor sit any higher than a regular b16? it seems that every one ive seen in a eg ej whatever fit just fine so why not the b16b?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver »</TD></TR><TR><TD CLASS="quote">...the ctr uses a b18 block so its a little taller. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrb03wrx »</TD></TR><TR><TD CLASS="quote">out of curiosity why would the ctr motor sit any higher than a regular b16? it seems that every one ive seen in a eg ej whatever fit just fine so why not the b16b?</TD></TR></TABLE>
it uses a b18c block w/ a b16 crank but uses custom rods (i think) which brings the displacement to 1.6L
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic »</TD></TR><TR><TD CLASS="quote">Just to let you know its EJ COUPE , and its teh bettar than teh hatchcrap!</TD></TR></TABLE>
EJ coupe can be both a coupe from 92-00.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
EJ coupe can be both a coupe from 92-00.</TD></TR></TABLE>
We know that but for a fact its a 95 coupe and it could be a ej1 or 2 .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importjunkie »</TD></TR><TR><TD CLASS="quote">i do plan on running p/s i just need either a new p/s pump or a new line. The d series p/s pump doesn't match up with the b-series brackets and the b-series p/s pump that came with motor doesn't match up with my lines.
For now i'm just letting it bolt to that mount to keep it secure and keep the lines plugged.</TD></TR></TABLE>
b16, 99-00 Si power steering pump works.
when i got my B18C installed into my '93 coupe (<--avoid debate!), it looked a lot higher than the stock z6; but i never had any problems closing the hood.
i've got integra mounts and managed to save the p/s and cruise control.
5150CIVIC
Dec 5, 2007 08:18 AM
