eg motor mount question
IM finishing up a swap from a coupe to a sedan and i need to replace some mounts while i have the motor out.
The mounts out of the coupe were shot to hell and my sedans mounts were **** to begin with.
The Engine is a JDM D15B manual and im swapping from an AT to the MT. I have the bastard *** special mount needed for that auto to manual swap.
My question is should i grab another set of mounts that would fit the sedan or should i grab some mounts that would fit in the coupe or are they just the same mounts anyway?
Re: eg motor mount question
they are the same mounts, you don't have to worry, but if you are buying new mounts for the drivers side and the rear, you need to see if you have a 3 bolt mount on the drivers side or a 2 bolt mount.. Just to make sure you get the right things.
ok coo beans. thanks bunches. i need to update my build thread. will do tomorrow. as a matter of fact i think I'll just make a new one
