need some advice
I have a 89 civic SI with around 208k that goes through about a court of oil a week and i wanted to swap the motor out this comming week(spring break). Now originally I had planned to go with a DOHC ZC, but most company's dont have any in stock. I have around $600 to spend, also im 16 and have some experience but probaly not enough to assemble a block or somethin as complicated as that. any advice would be cool. thanks
with 600 you should get a d16z6 or a d15b sohc motor because its basically much cheaper because you dont need swap mounts. And thier both pretty quick over stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-you »</TD></TR><TR><TD CLASS="quote">I have a 89 civic SI with around 208k that goes through about a court of oil a week and i wanted to swap the motor out this comming week(spring break). Now originally I had planned to go with a DOHC ZC, but most company's dont have any in stock. I have around $600 to spend, also im 16 and have some experience but probaly not enough to assemble a block or somethin as complicated as that. any advice would be cool. thanks</TD></TR></TABLE>
i'm in portland too... where are you looking to buy the motor from?
Musicman22
11
Jan 20, 2006 09:29 PM
