just got back from sac raceway......
Old Mar 16, 2005 | 11:17 PM
red_ek_hatch's Avatar
Default just got back from sac raceway......
ok well i have 97 coupe ex civic with full interior . i have a b16 sirII swap . i have a drivers side engine mount broken . my mods are : aem cold air intake , skunk2 intake manifold, comptech header, cat back exhaust . im running on 15" rotas with proxe 4 tires . ok on my first run i did , i did the best . i kept getting worse every time tell me if i should be getting better times with this setup and if i should around what times ? anyways heres the numbers:
reaction: .524
I1: 2.480
I2: 6.641
I3: 10.041
mph I3: 73.737
I4: 12.931
ET: 15.402
MPH: 92.548
M.O.V: 1.223
this was my very first time racing at the track . so how do you guy's think i did ? what should i be expecting from this setup the way it is ? remember my drivers side engine mount is brocken .
Old Mar 17, 2005 | 12:58 PM
JSpin's Avatar
Default Re: just got back from sac raceway...... (red_ek_hatch)
your trap speed is high for the time that you ran...........work on your launch, simple as that.
Old Mar 17, 2005 | 01:05 PM
aut0tek's Avatar
Default Re: just got back from sac raceway...... (JSpin)
-I retract my previous statement...
The engine mount needs fixed ASAP if you plan on going fast... You need to cut the 60' down a bit.
I still think the last shift was ugly at best.
Ratliff
Old Mar 17, 2005 | 01:14 PM
JSpin's Avatar
Default Re: just got back from sac raceway...... (aut0tek)
here's an old slip of mine
I1 2.263
I2 6.17
I3 9.446
mph 73.9
I4 12.255
14.624
95.219
his 1/8 mile trap speed is high too, crappy 60foots tend to lead to higher than normal trap speeds. with a good launch, i think his car has a high 14 in it
autotek.........you post editing *****
Old Mar 17, 2005 | 06:49 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_ek_hatch &raquo;</TD></TR><TR><TD CLASS="quote">ok well i have 97 coupe ex civic with full interior . i have a b16 sirII swap . i have a drivers side engine mount broken . my mods are : aem cold air intake , skunk2 intake manifold, comptech header, cat back exhaust . im running on 15" rotas with proxe 4 tires . ok on my first run i did , i did the best . i kept getting worse every time tell me if i should be getting better times with this setup and if i should around what times ? anyways heres the numbers:
reaction: .524
I1: 2.480
I2: 6.641
I3: 10.041
mph I3: 73.737
I4: 12.931
ET: 15.402
MPH: 92.548
M.O.V: 1.223
this was my very first time racing at the track . so how do you guy's think i did ? what should i be expecting from this setup the way it is ? remember my drivers side engine mount is brocken .</TD></TR></TABLE>
Last night was crazy out there. It was sold out. They went pretty slow at first it seemed but picked up pretty nicely surprisingly. I would up redlighting and was done after only 4 passes. Your times aren't too horrible, but the 60 is what is killing you. You have the mph for a high 14 second pass.
Old Mar 17, 2005 | 07:21 PM
DownshiftDb8's Avatar
Default Re: just got back from sac raceway...... (Hybrid93Eg)
hmm i was out there. car broke down snapped a axle..
Old Mar 17, 2005 | 11:33 PM
Default Re: just got back from sac raceway...... (DownshiftDb8)
yeah that day was actually my first day racing that car !!! so i guess i wasnt that bad huh ? but yeah the first 60' is killing me ! i believe my reaction time sux too ! i think that broken motor mount is afecting me really bad ! hopefully it gets fixed this weekend .
i have a few other things im goin to add to the car but i also want to get the car tuned when i get that stuff installed . im goin to add: a test pipe , b&m fuel pressure regulator ,
AEM adjustable cam gears, and a APEXI VAFC and of course im goin to get all that stuff dyno tuned . what should i be running with that extra stuff ????
yeah it was decent amount of people at the beguining and then later on it got packed . it was fun..
Old Mar 18, 2005 | 07:51 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_ek_hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah that day was actually my first day racing that car !!! so i guess i wasnt that bad huh ? but yeah the first 60' is killing me ! i believe my reaction time sux too ! i think that broken motor mount is afecting me really bad ! hopefully it gets fixed this weekend .
yeah it was decent amount of people at the beguining and then later on it got packed . it was fun.. </TD></TR></TABLE>
I wouldn't waste my time with a VAFC, fix it the right way and get a Hondata or chipped P28. The gears will be pretty much worthless on stock cams and the test pipe will get you tossed on Wednesday if they find it. Especially considering in California its a federal offense to remove the cat. But hey, each to his own.
Reaction time has nothing to do with your 1/4 mile time either.
Old Mar 18, 2005 | 11:55 AM
i already have the fuel regulator and the cam gears . i dont have the test pipe and the vafc yet . im thinking twice about the test pipe , and the vtech controller . i dont think i'll do those . im running a itr ecu at the moment . what can i do with that ? can that get chipped?
if nothing what are my options on getting onother ecu and chipped . and how much $$$$ would it be ?
Old Mar 18, 2005 | 12:02 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_ek_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i already have the fuel regulator and the cam gears . i dont have the test pipe and the vafc yet . im thinking twice about the test pipe , and the vtech controller . i dont think i'll do those . im running a itr ecu at the moment . what can i do with that ? can that get chipped?
if nothing what are my options on getting onother ecu and chipped . and how much $$$$ would it be ? </TD></TR></TABLE>
You need an OBD-II to OBD-I conversion harness and then some form of chippable OBD-I ecu. If you want to keep the knock sensor enabled, you need a P72, P30, P61. If you don't care about the knock sensor, then a P28 will work just fine. Once you have those, you need the ECU chipped. If you want, I will chip it for you, or there are other people on Honda-tech offering the service also. Its fairly cheap and will get you headed in the right direction. Problem is without a wideband and someone with a burner near you, you can't really "tune" the setup. You might be better off in this situation getting a Hondata and taking it to your local Hondata tuner (if you have one).
Old Mar 18, 2005 | 12:12 PM
im preatty new to this engine stuff , so sorry if i have too many questions. but anywayz . ok if i get a hondata . how much is that ? how much will that improve performance and reliability on the engine ?
Old Mar 18, 2005 | 02:07 PM
JSpin's Avatar
hondata is a "stand alone" type managment system that runs off the stock ecu. personally, i think it's an overkill for your car at this point in time. it can get very expensive depending on what options you decide to get; i'd say AT LEAST 500 bucks all said and done.
you need to figure out how far you want to go with your car before you start looking at tunning options.
Old Mar 18, 2005 | 02:13 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">hondata is a "stand alone" type managment system that runs off the stock ecu. personally, i think it's an overkill for your car at this point in time. it can get very expensive depending on what options you decide to get; i'd say AT LEAST 500 bucks all said and done.
you need to figure out how far you want to go with your car before you start looking at tunning options. </TD></TR></TABLE>
Standalone yes, but don't mislead him saying it will work with his current ECU. He will still need to convert it to OBD-1 and obtain an OBD-1 ECU.
Old Mar 19, 2005 | 10:24 AM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Standalone yes, but don't mislead him saying it will work with his current ECU. He will still need to convert it to OBD-1 and obtain an OBD-1 ECU.</TD></TR></TABLE>
i was refering to the fact that hondata works with a stock honda ecu, and not a complete stand alone, but i suppose that is misleading. yes, you do need to convert to obd1.
Old Mar 19, 2005 | 02:17 PM
goforbroke's Avatar
MEAT PATTY
Why do people go to the dragstrip with broken motor mounts and beat the crap out of their cars.
Old Mar 19, 2005 | 03:05 PM
Default Re: just got back from sac raceway...... (goforbroke)
ok well we just installed my hasport mounts . the vibration is not bad at all .. maybe its just me . i dont chirp as much in second either . my rear mount wasnt even bolted in when we checked it . that means i had a torn mount , and a unbloted rear mount . yeah i would have to say thats all bad . but we fixed it so its all good now . im happy with the mounts .
moshi moshi
19
Aug 30, 2005 02:56 PM
red_ek_hatch
Mar 16, 2005 11:45 PM
red_ek_hatch
Mar 16, 2005 11:30 PM
red_ek_hatch
Mar 15, 2005 05:38 AM
red_ek_hatch
Mar 12, 2005 07:45 PM
