Suspension & Brakes Theory, alignment, spring rates....
is it the alignment?
Old Mar 16, 2005 | 10:45 PM
neopheus's Avatar
Default is it the alignment?
today i got a flat tire. luckily it lasted long enough for me to get to the shop. i knew i needed an alignment but now that i got two new tires in the front the car shakes bad when i go between 60-80. is it the alignment or prolly cuz the tires werent balanced? i bought the tires used but they looked pretty darn good. the car never shook with the old tires. give me help.
Old Mar 16, 2005 | 11:01 PM
Dirk-EG's Avatar
Shaking = balancing or lack thereof. Or nasty flat spots on the surface of the tire.
If the car doesnt want to go in a straight line on a flat surface, then you have an allignment problem. Bad allignment will also wear out your tires really fast, which will show within weeks.
Old Mar 17, 2005 | 08:02 AM
itslogics's Avatar
Default Re: (Dirk-EG)
check the back tires for "humps" through out the tire. If there is, than you need to replace the back two also.
Old Mar 17, 2005 | 07:38 PM
frankdatank's Avatar
if it vibrates in the front of the car, like the steering wheel, thenits usually balance/bent wheel, or tire hop
Old Mar 17, 2005 | 08:02 PM
migs's Avatar
Default Re: (frankdatank)
What you just described is the wheel balancing. Flat spots in tires are typically a seperated belt (unless you locked em up). A seperated belt will be felt at ALL speeds.
nemesiskrp
19
Sep 14, 2007 08:30 AM
Honda.F1
Honda Civic (2001 - 2005)
Oct 18, 2006 04:35 PM
easyFOsheezy
Apr 7, 2006 01:24 PM
Type R 01
Oct 1, 2002 01:21 PM
