ls/vtec swap.help!
my buddy and i swapped in an ls/vtec..got all the plugs in..except for 1..the plug thats by the resistor box (the silver thing)..wont plug in with the motor harness 1..the motor plug has 14 pins..the plug by the resistor has 8 pins..wth??..can u guys please help me out here..its a 90 crx si..i asked some guy and he said the 88-89 have 14 pins and the 90-91 have 8 pins...please help.hope u guys know what im talkin about and 1 more thing..what alternator belt do i ask for when i buy it at an auto parts.? i asked for a 95 ls belt but it was too big.im usin a ctr pulley..1st gen.b16 head/b18b ls bottom end...thanks guys
Did you modify the Si harness, run a sub harness or are you actually trying to use the wiring harness that came with that engine (or head, whatever)?
for that setup you want to stick with the Si wiring, and use a sub harness for the new plugs.
YOU CANNOT USE THE WIRING HARNESS THAT COMES WITH ANY B SERIES ENGINE
And heres the sub harness - http://www.rywire.com/sitob160.shtml
Modified by NikoZai at 1:44 AM 3/17/2005
well im not sure if im usin the engine harness from this car..its my cousins car.he bought a crx shell and the owner gave him the harness.he said it was from that car..when i was pluggin em in.i noticed that the harness was already wired up for vtec..what im tryin to do now is findin a 90-91 crx si harness...ne more tips will be appreciated..thanks guys
hey..1 more question..what alternator belt do i buy??? i bought an ls belt but it was too long...its a b16 head with an ls bottom ened b18b..i got it all plugged in now..just need to get the belt now..ill be here for an answer..thank u
i just want to point out that YOU CAN USE A JDM ENGINE WIRE HARNESS! if you know your wiring then it can happen. last one i did was a 89 crx hf with a jdm sir b16a with jdm harness. all it was was to change the driver's side connector(vehicle side) to the bigger connector to fit the jdm connector and run about 5 wires from the drivers side to the passenger side.
yo. your just gonna have to match up the size of the belt at kragen, pepboys,etc. there should be a number on the belt that will be in millimeters. ie. 909, 875..etc. for example...if your belt is too long then just a shorter one
1nsoman1ac
10
Sep 22, 2009 01:08 PM
4gencivicef9
May 21, 2008 04:44 PM
