knock sensor..help me please
Old Mar 16, 2005 | 09:49 PM
iLovPhoKing's Avatar
Default knock sensor..help me please
ok well this is the deal. i have a 99 gsr motor that i am putting into my ek. the knock sensor on the motor is broken. my question was do i still need to run it even if i have a kenji chipped p28 ecu?
Old Mar 16, 2005 | 10:58 PM
Greasemonkey's Avatar
hmm. I think the motor will run, but you will run on limp mode because the OEM ECU will look for it.
The knock sensor there to listen to your motor for any misfire so it could retared your timing. Best bet is to get another one, but they can be expensive at the dealer. Find a use one and it would work. You can get it at the junk yard too.
Old Mar 17, 2005 | 06:30 AM
Jmunk's Avatar
Mines broke, i'm waiting on a my chipped p72 to get here so i don't have to run one. Lots of people don't run them.
Old Mar 17, 2005 | 07:58 AM
Default Re: (Jmunk)
thanks for the help...need a lil more reassurance so BUMP..
Old Mar 17, 2005 | 08:01 AM
snatch's Avatar
Default Re: (iLovPhoKing)
You said you're using a P28 ECU, I thought that ECU doesn't look for a knock sensor. I might be wrong, but that seems to be in my head.
Old Mar 17, 2005 | 08:05 AM
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">You said you're using a P28 ECU, I thought that ECU doesn't look for a knock sensor. I might be wrong, but that seems to be in my head.</TD></TR></TABLE>
yea im using a kenji chipped p28..and i hope that you are right
Old Mar 17, 2005 | 08:07 AM
civic-4-ges's Avatar
Hes correct...no knock sensor circuitry in a p28
Scotty B
Mar 26, 2021 03:15 PM
dkrex001
Oct 1, 2006 10:34 PM
JDMlyfestyle
Jul 5, 2003 09:01 AM
hatchboy93
Apr 25, 2003 03:58 PM
