Finished 6th gen Accord swap the other day......Just wanted to do a rundown
Old Mar 16, 2005 | 06:00 PM
jdmaddiction's Avatar
Default Finished 6th gen Accord swap the other day......Just wanted to do a rundown
We did it in a 1.5 days,
*First day we removed the motor and started swapping parts over to the H
*Second day was the install
Components
-Swapped AC Compressor + Bracket (used F Series)
-Swaped Alt and used the H22 bracket (clearance problems with the other options)
-The H22 PS pump and bracket
-Had to get a longer belt for the AC/Alt
-Had to splice the PS line lower from F and upper from H
Mounts
-Swaped over the Drivers side motor mount bracket(to the motor only 3 of the 4 bolts
lined up) had to do a little grinding to make it fit and also trim the cover.
-used all of the stock F mounts and brackets
Throttle cable
-used the H bracket and then modified the cable under the dash using a Ebrake cable repair
kit
Drive
-Used the F mid shaft
-Used the F axles
-used the F cables and shifter
-swapped over the F Slave and bracket
Radiator
-Used the lower Rad hose from the F
-Used the upper from an H
Sensors changes
-had to extend some wires for coolant and such
-rewired in the OBD1 Distributor, while doing that we had to pull a ignition switched
wire from the dash in-order to get power to the dist.
-IAC had to be rewired from a 3 wire to a 2 wire (1 signal and other ground)
-CAS CPS had to be rerouted to the dist.
-rewired the injectors from the OBD2 to OBD1 and added in the resistor box.
-If using the EGR use the one from the F motor
-O2 sensors....we eliminated the secondary to we made a jumper harness (plugs on both ends)
to move the primary O2 to the rear on the DP
-Used the Boomslang OBD2b to OBD1 conversion harness (good people and good products)
Exhaust
Had to get it modified for fitment
Eliminated
-EGR
-Secondary butterflys
-Knock sensor
(only because we used our P28-ECU tune on it OBD1)
*****this was just personal choice not needed*********
there might be more but this is all I could think of at the time just wanted to get this
out for you guys if anyone has any question feel free
http://WWW.JDMaddiction.COM
Old Mar 19, 2005 | 11:56 AM
00accordse's Avatar
Please post up some pics of the swap.
Thanks
Old Mar 19, 2005 | 12:19 PM
Carolina Fried Rice's Avatar
Default Re: (00accordse)
sounds like fun.
Old Mar 19, 2005 | 10:34 PM
iand415's Avatar
Default Re: (TSAF22B1)
i wanna see pics!!
Old Mar 20, 2005 | 07:30 AM
Default Re: (iand415)
Ill get some pics up within the next couple of days
Old Mar 20, 2005 | 07:32 AM
Default Re: (jdmaddiction)
I think I forgot to mention we had to modify the fuel line also......because it was wanting to look like a "Z" it was working ok but wasnt right...........
Old Mar 20, 2005 | 07:58 AM
Corruption's Avatar
Default Re: Finished 6th gen Accord swap the other day......Just wanted to do a rundown (jdmaddiction)
Nice man, how much do you think you spent on everything? I have an 01' Accord and I'm contemplating on some FI or an engine swap in the future....
Old Mar 20, 2005 | 11:17 AM
-Bionic-'s Avatar
Former Sponsor
Everything sounds about right. Great write up.
I used all of the accord mounts and brackets [including engine bracket]
Is the upper H radiator hose 100% flush?
I used the one from an accord and there was a slight kink, and I had to use a o-ring to straighten it out.
Once again nice writeup.
EDIT: What year H upper radiator hose did you use?
Old Mar 23, 2005 | 05:49 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Finished 6th gen Accord swap the other day......Just wanted to do a rundown (-Bionic-)
Bump.
Old Mar 23, 2005 | 06:00 AM
rdmts's Avatar
Bump
Old Mar 23, 2005 | 06:06 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: Finished 6th gen Accord swap the other day......Just wanted to do a rundown (rdmts)
lol
You bumped it 11 minutes later.
Welcome to HT.
Old Mar 23, 2005 | 07:06 AM
H rad hose worked good, the accord one was kinked.....
Old Mar 23, 2005 | 07:12 AM
Engine- $2200 (complete swap bought from us)
Parts- $200 (oil,filter,stat.conversion harness,hoses,etc.
Install- free by us at JDM addiction (friend benefit)
Chipped ECU- $175 including the ECU
So I guess he didnt do to bad on the install LOL
Old Mar 23, 2005 | 07:28 AM
-RedneckDave-'s Avatar
Working
Well done. I love seeing swapped 6th gens.
Old Mar 23, 2005 | 07:44 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaddiction &raquo;</TD></TR><TR><TD CLASS="quote">H rad hose worked good, the accord one was kinked.....</TD></TR></TABLE>
So does it matter which generation/year prelude radiator hose I use?
Thanks
Old Mar 24, 2005 | 05:11 PM
The car is in the process of getting a paint job
anyways if any other pics are needed or wanted ask
Old Mar 24, 2005 | 05:28 PM
BDietrich84's Avatar
Very Nice! i want a h22 in my 94 ex coupe, but i couldnt find 3000 dollars if i sold my soul to the devil. i see you used the stock air box, did you leave the resonator tank on or did you drop it for the extra airflo.
Old Mar 24, 2005 | 06:47 PM
Default Re: Finished 6th gen Accord swap the other day......Just wanted to do a rundown (BDietrich84)
no that is out and the stock Accord box and tub was used
Old Mar 24, 2005 | 06:49 PM
BuCxLuXoRX2o0o's Avatar
nice work, maybe one day i will have one of these in my car.....one day
Old Mar 24, 2005 | 08:09 PM
as for the rad hose we used one for a 94 application h22
Old Mar 25, 2005 | 04:42 AM
Turbowa's Avatar
Its about time some one did an H22 swap into a 6th gen thats clean.
Congrates man
Old Mar 25, 2005 | 05:22 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaddiction &raquo;</TD></TR><TR><TD CLASS="quote">as for the rad hose we used one for a 94 application h22</TD></TR></TABLE>
Hey thanks.
Old Mar 25, 2005 | 12:08 PM
booja's Avatar
nice.....
look at all that space in front for a crazy manifold and big snail
Old Mar 25, 2005 | 01:31 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (booja)
Thats a rare sight to see. Good ****
Old Mar 25, 2005 | 03:12 PM
Default Re: (cb7-R)
thanks
