si head into dx?
Old Mar 16, 2005 | 05:42 PM
ekoms31's Avatar
Default si head into dx?
i have order a 89 si head and i am wondering if the wiring harness of a dx model comes with a vtec wire so i can put in vtec because i have read that some cars come with a vtec wire harness when the car is not vtec.
Old Mar 16, 2005 | 05:57 PM
Magick211's Avatar
Default Re: si head into dx? (ekoms31)
No usdm ed's had vtec wires in the wire harness
Old Mar 16, 2005 | 05:59 PM
Gumbey75's Avatar
huh? your trying to put a 89 si head thats non-vtec and hopeing that vtec will magically engage? there are no vtec wires on our usdm stock crx's you have to get that from different places. if you have a dx model you have 2 injectors and the si head will have 4 so u have to do the mpfi swap.
Old Mar 16, 2005 | 06:11 PM
ekoms31's Avatar
Default Re: si head into dx? (Gumbey75)
are you saying that if i swap heads i would have to change to mpfi or you saying it for vtec
Old Mar 16, 2005 | 06:41 PM
Burlyirishdude's Avatar
your motor....will not have vtec....ever...simply b/c the motor you have never had vtec..even if you swap the head....there's no oil jets in the cylinder walls none fo the "hardware" for vtec is present on your motor block...So no vtec....
However if you put an SI head on the dx motor...the si had more injectors...so you'll have to rewire some stuff for it to manage the new injectors....cool? I hoep i helped a little and didn't sound like a dick....good luck
Old Mar 17, 2005 | 12:44 PM
ekoms31's Avatar
Default Re: si head into dx? (Burlyirishdude)
what kind of wiring
Old Mar 17, 2005 | 12:56 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude &raquo;</TD></TR><TR><TD CLASS="quote">your motor....will not have vtec....ever...simply b/c the motor you have never had vtec..even if you swap the head....there's no oil jets in the cylinder walls none fo the "hardware" for vtec is present on your motor block...So no vtec....</TD></TR></TABLE>
what are you talking about? Have you ever heard of a mini-me swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">However if you put an SI head on the dx motor...the si had more injectors...so you'll have to rewire some stuff for it to manage the new injectors....cool? I hoep i helped a little and didn't sound like a dick....good luck</TD></TR></TABLE>
This is only if you swap intake manifolds (which would be smart). Honestly, the dx head flows just as well as the Si from what i've seen so swapping them would be pointless unless it's lower miles or rebuilt or something and you're burning oil/doing head gasket anyways. Just do the mpfi conversion on your dx (just swap intake manifolds and do wiring) and be happy with that.
And do a search for "mpfi conversion" and you'll see the wiring you have to do. You also have to swap to a pm6 ecu (Si)
Old Mar 17, 2005 | 05:55 PM
ekoms31's Avatar
Default Re: si head into dx? (njn63)
my dx has a stuck valve that why i had to swap it. all i what to do is drive it and where can i find a dx head
so if i put in the si head i would have to convert it to mpfi and
i would have to use an auto pm6 too because my car is auto
Modified by ekoms31 at 11:47 AM 3/18/2005
Old Mar 18, 2005 | 07:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">what are you talking about? Have you ever heard of a mini-me swap?
I stand corrected...wasn't thinking that far ahead...
Old Mar 18, 2005 | 10:24 AM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekoms31 &raquo;</TD></TR><TR><TD CLASS="quote">my dx has a stuck valve that why i had to swap it. all i what to do is drive it and where can i find a dx head
Modified by ekoms31 at 11:47 AM 3/18/2005</TD></TR></TABLE>
you can leave it dpfi if you want. Just use the intake manifold that is on your car.
Old Mar 18, 2005 | 11:26 AM
Its me DUB's Avatar
a good description of what vtec is and how it works...
http://auto.howstuffworks.com/question229.htm
Old Mar 18, 2005 | 11:59 AM
ekoms31's Avatar
so just swap the head and it would run
Old Mar 18, 2005 | 07:24 PM
ekoms31's Avatar
do i need any thing for the swzp
Old Mar 18, 2005 | 07:35 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekoms31 &raquo;</TD></TR><TR><TD CLASS="quote">do i need any thing for the swzp</TD></TR></TABLE>
If all you want to do is swap the heads then just swap the heads nothing is needed. Now if you were changing the intake manifold to the Si intake manifold then yes there would be more work involved but head for head its a straight swap.
lsdisk0
Aug 4, 2013 05:00 PM
Layziebtnh055
Apr 12, 2004 09:12 AM
jwrcivicdx
May 2, 2003 05:56 AM
dose
Apr 23, 2002 04:56 PM
