HID help me identify these wires
Old Mar 16, 2005 | 05:39 PM
ek_will's Avatar
Default HID help me identify these wires
i just need help identifying neg and positive. i heard if i dont wiring them up correctly i can blow my bulb.
on the harness theres an A and B which is neg and positive, theres a black line on one wire but it looks like they may have been switched around so i just wana be certain.
thanks
Old Mar 16, 2005 | 06:34 PM
ek_will's Avatar
Default Re: HID help me identify these wires (dash_0n)
bump
Old Mar 16, 2005 | 06:45 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
those are the power wires i believe, but its weird that its not color coded so u cant tell which is the positive and which is the negative. the other wire is the actual plug for the bulb
Old Mar 16, 2005 | 06:54 PM
Shaun's Avatar
one wire goes into the ground wire, and the other the power, which will be low beam, you wont have high beam with that OEM kit, your only going to use two wires off your headlight harness, I belive the black is the ground, you wont blow the bulb just the fuse's if you swap each around
Old Mar 16, 2005 | 06:58 PM
s2kkk's Avatar
The wires on my Hella kit are yellow and brown.
BROWN=GROUND
YELLOW=HOT
Seeing that your **** is kinda rigged, I looked at my plug and B is HOT and A is GROUND.
Old Mar 16, 2005 | 06:59 PM
ek_will's Avatar
Default Re: HID help me identify these wires (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">those are the power wires i believe, but its weird that its not color coded so u cant tell which is the positive and which is the negative. the other wire is the actual plug for the bulb </TD></TR></TABLE>
i figured this much already, i really need help identifying the two wires on the harness im thinkin A = neg and B = pos ? anyone confirm?
Old Mar 16, 2005 | 07:01 PM
dmbmalaka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash_0n &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
thats a lot of chap stick.... i'm sooooooo jealous
CHAP STICK IS MY HERO
Old Mar 16, 2005 | 07:02 PM
s2kkk's Avatar
Blistek is mine.
Old Mar 16, 2005 | 07:10 PM
Shaun's Avatar
Default Re: (spoon.eg)
i figured this much already, i really need help identifying the two wires on the harness im thinkin A = neg and B = pos ? anyone confirm?</TD></TR></TABLE>
there is no neg. positive... its ground and power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">one wire goes into the ground wire, and the other the power, which will be low beam, you wont have high beam with that OEM kit, your only going to use two wires off your headlight harness, I belive the black is the ground, you wont blow the bulb just the fuse's if you swap each around</TD></TR></TABLE>
Old Mar 16, 2005 | 07:35 PM
saxqtzk's Avatar
If you look at the first pic there's some sort of electrical tape or something. You can see the black wire and yellow wire at the plugs end.
If you're going by the A and B then A is Ground and B is Power
Paul-eg
Lighting
Feb 15, 2009 09:35 AM
98savage
Lighting
May 21, 2008 02:13 PM
Fuster_Cluck
Lighting
Feb 26, 2008 12:03 PM
datssoled
Mar 29, 2007 03:22 PM
Sam268
Jan 6, 2004 12:05 PM
