swapping to a snap off s.wheel wat do i do about airbag oem ??
Old Mar 16, 2005 | 04:11 PM
HULKHATCH10's Avatar
Default swapping to a snap off s.wheel wat do i do about airbag oem ??
swapping my oem wheel for a snap off ....wat will i have to to so my sas or wat ever is cald light wont come on....so i pass inspection...thanx every one
Old Mar 16, 2005 | 04:17 PM
suspendedHatch's Avatar
Default Re: swapping to a snap off s.wheel wat do i do about airbag oem ?? (HULKHATCH10)
If you take apart the cluster, look where the yellow loomed wire harness plugs in. There's a screw or two holding a white plastic piece into the cluster. Remove that. Then put some electric tape to block light from seeping through the now open SRS warning light hole.
Old Mar 16, 2005 | 04:35 PM
Default Re: swapping to a snap off s.wheel wat do i do about airbag oem ?? (shaundrake)
thanx, will do .. is there a way to disconect the air bags ,i also have a passenger one 2 i dont want my insurance to deny me if i ever get into an accident which i already did but bags never deployded....thanx man
Old Mar 16, 2005 | 04:40 PM
Street Ghost's Avatar
What do you mean disconnect the airbag? Once you put on the aftermarket steering wheel.. your airbags will no longer deploy; not even the passenger one.
lsturbo00
Oct 5, 2009 04:22 PM
lsjon
Jun 17, 2009 02:11 PM
cdfive.
Apr 25, 2005 05:57 PM
mikehawkBUiLT
36
Aug 21, 2004 09:55 PM
RineRacing
20
Jan 24, 2003 06:55 AM
