Suspension & Brakes Theory, alignment, spring rates....
Fixing a cross threaded coil over perch?
Old Mar 16, 2005 | 02:46 PM
cheezit's Avatar
Default Fixing a cross threaded coil over perch?
I think the upper perch on my coilovers are crossthreaded. It won't go down, but i can get it to spin a little. It's currently soaking in WD40 to see if i can move it. They're Skunk2 coil overs over KYB AGX shocks. Is there a way to fix it if it is cross threaded, or am I just fucked? Thanky!
Old Mar 16, 2005 | 04:05 PM
Tyson's Avatar
Default Re: Fixing a cross threaded coil over perch? (cheezit)
UPPER perch? you mean the lower spring perch (at the bottom of the spring) you adjust??
why not disassemble the shock, remove the spring tension completely and check for yourself?
Old Mar 16, 2005 | 08:58 PM
cheezit's Avatar
Default Re: Fixing a cross threaded coil over perch? (Tyson)
I didn't have time for this. By upper, I meant the top of the lower locking portion. I mispoke. It ended up threading after enough tries. Thanks for the input.
masospaghetti
May 19, 2016 03:25 PM
RighteousMidwest
May 8, 2007 06:09 AM
-=N.E.O.=-
Suspension & Brakes
Aug 29, 2006 05:20 PM
moores55
Jan 15, 2006 12:37 PM
cpoore
Jun 1, 2003 08:32 AM
