Honda OEm door piece...frustrated
Old Mar 16, 2005 | 02:26 PM
Burlyirishdude's Avatar
Default Honda OEm door piece...frustrated
I went out and bought the Oem Face door piece, the one that every crx owner has lost at some point...The one that connects to the door and the trim fits over it right next to the window....anyway...
How do i put that on....I looked at the clips and suffice to say I'm angry i am going to break it....ANy help with how to properly secure this ******* piece to the door.
Old Mar 16, 2005 | 02:29 PM
tRex99's Avatar
Default Re: Honda OEm door piece...frustrated (Burlyirishdude)
i think ud have to buy new clips and all. it should have came with like what 3 clips on the black piece, then there should be 3 white clips inside the door. i know thats how it goes but not sure if they came with ur stuff.
Old Mar 16, 2005 | 06:37 PM
Default Re: Honda OEm door piece...frustrated (tRex99)
Ok on the door the slots on the door....where the white clips meet up on the door...And then where the window meets up with this thing...there are the clips inside of the door. So i don't know.....i am so argg....bleh...i'm gonna leave it alone for a while
Old Mar 16, 2005 | 06:40 PM
Quik89Si's Avatar
Probably not a bad idea. Let us know what you find out.
I just bought new OEM door moldings - just got these bad boys tonight. Anxious to get them in, here's hoping I don't have as much trouble as you are!
Good luck bro!
Alex
Old Mar 16, 2005 | 06:44 PM
tRex99's Avatar
Default Re: Honda OEm door piece...frustrated (Quik89Si)
yea but see the reason ur old one came off is because the black ends that stick out, broke off in the white things anyway most likely. so u can try to poke them out or just get NEW white clips and take a screw driver and go to hell on the other ones. then stick the new ones in and ur good to go. honestly id just change the white clips cause they get work and cracky so they break down the road and ur screwed again!
Old Mar 20, 2005 | 04:05 PM
got it to stick.....I love it....and i just finished installing my new regulator....and my window works again now.....my car is slowly coming back to life....Cosmetically
Old Mar 20, 2005 | 04:08 PM
steronz's Avatar
for anyone else who reads this, here's how i did it:
the new pieces should come with 3 white clips in the middle, and 3 intact plastic "loops" that connect to 3 clips already in the door. roll down the window, pull out the rubber molding that the window slides up, and there should be 6 screws, three of which hold those white clips in. remove screws and clips, clip the clips onto the plastic piece, snap it to the door, replace screws, replace molding, roll up window, have beer.
Black Diamond
16
Aug 24, 2010 07:13 PM
theineffable
Honda Civic (2001 - 2005)
Mar 15, 2010 01:17 PM
B18Redline
Apr 15, 2004 11:27 AM
Ciba
Jun 3, 2002 07:56 AM
p0pe
Mar 18, 2002 03:31 PM
