B16A swap
Old Mar 16, 2005 | 02:18 PM
HondaTeg95's Avatar
Default B16A swap
Were putting a B16A into a 94 ex civic, it is an obd0 motor going into a obd1 car so what all do we need to make that work, a distrubutor and a new ecu right? what should the ecu and distrubutor come off of? a obd1 b16a?
Old Mar 16, 2005 | 02:25 PM
dmbmalaka's Avatar
Default Re: B16A swap (HondaTeg95)
what kind of b16a?
Old Mar 16, 2005 | 02:43 PM
burnitup's Avatar
if its obd0 its got to be the jdm first one in the crx. any way you will need a obd1 a full dizzy, wire harness for your ecu from obd0to obd1 and the obd1 ecu for your motor or a chiped p28 will work. all and also you should upgrade to a obd1 intake mani because of the crazy vacum design on the intake mani. i think thats it but i would go to http://www.pgmfi.org i think they have some info on how to do it some were in there website. hope this helps.
Old Mar 16, 2005 | 02:46 PM
antiJDM's Avatar
Default Re: B16A swap (dmbmalaka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmbmalaka &raquo;</TD></TR><TR><TD CLASS="quote">what kind of b16a?</TD></TR></TABLE>
you're serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">Were putting a B16A into a 94 ex civic, it is an obd0 motor going into a obd1 car so what all do we need to make that work, a distrubutor and a new ecu right? what should the ecu and distrubutor come off of? a obd1 b16a?</TD></TR></TABLE>
you need an obd1 alt. obd1 diz. obd1 injectors or stock b16's with resistor box, obd1 O2 sensor, stock wire harness from ex, stock ecu-socketed and chipped with p30 program.
Old Mar 16, 2005 | 03:45 PM
HondaTeg95's Avatar
Default Re: B16A swap (2thousandcivic)
ok now im lost, i need the diz, i have to get new injectors? and a p30 will work? will i need an intake manifold too?
Old Mar 16, 2005 | 04:49 PM
antiJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">ok now im lost, i need the diz, i have to get new injectors? and a p30 will work? will i need an intake manifold too?</TD></TR></TABLE>
the injectors that came on your b16 are meant to run in conjuction with the resistor box. a p30 will work if you have one, and you will NOT need a new intake manifold, although the obd1's without the throttle/shifting control POS are better.
Old Mar 16, 2005 | 05:39 PM
Del Sol SiR's Avatar
You can go OBD1 or OBD2. To do OBD1 you'll need the parts from a 94-95 Honda Del Sol VTEC, for OBD2 you'll need parts from 96-97 Honda Del Sol VTEC or 99-00 Honda Civic Si. * When I say parts, I mean ecu, shift linkage, dizzy, sensors, etc...
Old Mar 17, 2005 | 12:16 PM
dmbmalaka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote">you're serious?
someone posting about a b16a swap with 3 post saying that it is obd 0 sounds kinda weird. considering that the only b16a's that are obd 0 are the b16a SiR (1) and the JDM integra Xsi and Rsi.
that would be why it would be nice to know what b16a it is
dont attempt to flame unless you know
Novtecdohc
Dec 3, 2005 03:55 AM
casper625
Nov 24, 2003 08:04 PM
SiRex91
Sep 9, 2003 01:09 PM
