RSX Greddy Turbo kit w/ intercooler
i see a couple on ebay right now. there is nothing wrong with the emanage system as long as you get the wiring right, alot of peeps are running them with the greddy kit. as for me, if got the kpro instead
Greddy and Cybernation are both good kits. The greddy kit is a good kit. If you end up purchasing it though you will want to change both the oil return line and oil feed line. There have been incidents where vehicles have caught fire because the lines have failed. Might as well be safe than sorry. Just have some SS lines made and it will be fine. Dont forgot to heat rap your steering line either, its a little close. If you pick up a cybernation kit the intercooler piping is total ****. There are trade offs you need to consider for both kits. As far as ECUs both the E-manage and Guardian ECU systems have room for imrpovement. Basically if you turbo you will need to upgrade your engine management. K-pro is the best out there. Good luck with your decision
Lawrence
Lawrence
ditto,
both kits engine management are
, do yourself a favor and swap it out for an AEM EMS and you'll be golden
ditto,
Reborn
Nov 1, 2006 01:51 PM
Sohc Driver
Mar 2, 2005 06:35 PM
