Installed Zeitronix, now car won't start
Old Mar 16, 2005 | 01:43 PM
honda_joe's Avatar
Default Installed Zeitronix, now car won't start
Car: 99 CX Hatch
Motor: 00 USDM H22a4
I installed my Zeitronix WB02 sensor today and soldered all the ECU connections. I went to start my car and nothing happens. I have power getting to the accessories. there is no voltage when the key is in the ON position at the main power pin at the ECU. What fuse controlls this connection?
I checked the fuel inj fuse and it was fine. I lost my diagram for the drivers side fusebox so I don't know what to check for there.
Old Mar 17, 2005 | 07:43 AM
honda_joe's Avatar
Default Re: Installed Zeitronix, now car won't start (honda_joe)
Any suggestions? Could it be the main relay? I hear no clicking coming from it
Old Mar 17, 2005 | 07:48 AM
Kamin's Avatar
its something you did because an o2 sensor itself wont cause the car not to start
you knocked something loose, blew a fuse, wired it wrong etc. 1000 different things could be the cause. just approach it like a normal "nostart" problem and see where that gets you. check voltages at the battery, starter, key, etc
2lua's Avatar
did you disconnted the battery before you wire the wbo2? check all the under hood and dash fuses.
Old Mar 17, 2005 | 07:54 AM
honda_joe's Avatar
Default Re: Installed Zeitronix, now car won't start (2lua)
What does power need to go through before it gets to the ECU? I checked EVERY fuse under the hood and they are all good. I'm gonna start checking the dash ones later.
There is ZERO voltage at the ECU. Something is broken in line with that. I can't figure out what though.
Old Mar 17, 2005 | 08:00 AM
Luserkid's Avatar
Possibly a bad ground maybe?
Old Mar 17, 2005 | 09:11 AM
Kamin's Avatar
it would be at the dash fuse box if your main relay dosent have power.
Old Mar 17, 2005 | 03:43 PM
honda_joe's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Possibly a bad ground maybe? </TD></TR></TABLE>
DING DING DING
It turns out I accidentally pulled the ground wire for my alarm out of its terminal when I unhooked the battery. My alarm has auto-immobilization built in which creates an open circuit when the alarm is disconnected. Connect the ground and she fired right up.
Now if I could only get it to run smooth on Uberdata....
Old Mar 17, 2005 | 03:55 PM
modedicebox's Avatar
Default Re: (honda_joe)
well done
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
egcivic
Nov 20, 2006 05:32 PM
dennis278
10
Jun 23, 2006 08:45 PM
94SiHatch
Nov 9, 2004 08:04 AM
