aliment and drag racing
Old Mar 16, 2005 | 01:03 PM
vaporboy12's Avatar
Default aliment and drag racing
here is my question. how important to have a good aliment when drag racing? what should it be set at toe and chamber wise?
Old Mar 16, 2005 | 02:09 PM
blackmagicCRX's Avatar
Default Re: aliment and drag racing (vaporboy12)
That is a good ? I would like to know the answer to that also? And what are good settings for caster???
alignment is how it is spelled by the way
Old Mar 16, 2005 | 02:34 PM
86si's Avatar
Default Re: aliment and drag racing (blackmagicCRX)
alignment is very important. you want as much tire as possible to make contact with the track
Old Mar 16, 2005 | 02:59 PM
Default Re: aliment and drag racing (86si)
I think I understand the camber settings. You want to set the camber to neg X degrees so that when the front end is at the highest point of lift you get 0 degrees of camber which in turn gives you the largest contact patch on the tire. But how does caster and toe affect suspension when it comes to drag racing?
Old Mar 16, 2005 | 03:12 PM
99blackcivicSi's Avatar
well toe would come into affect to avoid the tire from "scrubbing" and waring funny, thats not optimal preformance, and if you allow 1 inch of travel in the rear. so that the front lifts about an inch, i think you want -.5 degrees of camber roughly, and i don't know about caster, someone inform me please
Old Mar 16, 2005 | 03:16 PM
skunked's Avatar
Default Re: aliment and drag racing (99blackcivicSi)
https://honda-tech.com/zerothread?id=448278
Old Mar 16, 2005 | 03:34 PM
Default Re: aliment and drag racing (skunked)
What about for the rear suspension??? And also I understand that you want positive caster but about how much?? It wasn't very clear in the link posted.
Old Mar 17, 2005 | 01:01 PM
no one knows about the caster or rear alignment???
Old Mar 30, 2005 | 12:23 PM
vaporboy12's Avatar
what do i set the toe at on each side? not in inches please my hunter machine is in metrics
Old Mar 30, 2005 | 12:50 PM
vaporboy12's Avatar
anyone wnat to help me out
Old Mar 30, 2005 | 04:41 PM
vaporboy12's Avatar
help
Old Mar 30, 2005 | 09:30 PM
vaporboy12's Avatar
someone please
Old Mar 30, 2005 | 09:55 PM
Bspec18's Avatar
for FWD Drag cars, Front: you want positive caster, a little negative camber, and Toe in the tires
Old Mar 10, 2007 | 04:55 AM
DaveF's Avatar
Default Re: aliment and drag racing (Bspec18)
what have you learned ? read any books lately ?
acmoc
Dec 1, 2008 03:58 PM
y49crxsi
23
Dec 4, 2004 08:03 AM
tthame1
Dec 19, 2003 06:55 AM
itr1236
Sep 24, 2002 06:18 AM
