93 ex with b18c5
Old Mar 16, 2005 | 01:01 PM
bigmouthcivic's Avatar
Default 93 ex with b18c5
i have the swap in and running but has problems with idle, and when i give it gas it cuts out. I was thinking new fuel pump or fuel regulator. not sure what to do, any ideas would help thanks
Old Mar 16, 2005 | 01:28 PM
eK9aT10pSi's Avatar
Default Re: 93 ex with b18c5 (bigmouthcivic)
what ecu are u using ? sensors hooked up, such as map & tps ?
Old Mar 16, 2005 | 04:23 PM
Default Re: 93 ex with b18c5 (eK9aT10pSi)
chipped 28 (skunk2) and everything is hooked up right
Old Mar 16, 2005 | 04:44 PM
RedDC5's Avatar
what kinda ecu are u using?
RedDC5's Avatar
Default Re: 93 ex with b18c5 (4door_ridin)
oh wait, never mind. Loving the avatar BTW, im a big roots fan.
Old Mar 21, 2005 | 10:24 AM
problem solved runs great
Old Mar 21, 2005 | 01:46 PM
eK9aT10pSi's Avatar
what was it ?
Old Mar 21, 2005 | 04:16 PM
i replaced the fuel pressure regulator and a few new ground wires and it runs like a champ now
Old Mar 22, 2005 | 03:54 PM
RedDC5's Avatar
Did u use an aftermarket FPR? Does it improve anything?
existanzcivicb20
27
Jul 11, 2022 04:34 PM
eric587
Mar 1, 2014 06:00 AM
trevfz1
Feb 19, 2014 03:13 PM
bigmouthcivic
Mar 16, 2005 08:43 PM
slimcivic95
Oct 28, 2004 11:41 AM
