who makes runners for custom itbs
Old Mar 16, 2005 | 12:44 PM
2k.civic.si's Avatar
Default who makes runners for custom itbs
im looking for a set of runners for my steel b16 intake flange...im using hayabusa 46mm itbs if that helps?
Old Mar 16, 2005 | 03:24 PM
Default Re: who makes runners for custom itbs (2k.civic.si)
awsome...just the answer i was lookin for
Old Mar 17, 2005 | 06:38 AM
weiRtech's Avatar
OG Fabricator
i can. hit me with an email: aaronweir@cogeco.ca
here is a set of runners for some webers i made for someone.
Old Mar 17, 2005 | 09:45 AM
743power's Avatar
Default Re: who makes runners for custom itbs (weirRacing)
can you make the head flanges with injector bosses? Interested in something for an intake manifold.
Old Mar 17, 2005 | 10:06 AM
beepy's Avatar
Are those MIG'd? Look pretty good. Did you cut your own flanges or do you know of a place that sells the flanges?
Old Mar 17, 2005 | 10:32 AM
H23vtecEG's Avatar
Default Re: who makes runners for custom itbs (beepy)
check sign. those pix are very old i now make cnc im flanges. but it will give you a brief discription of the runners
Old Mar 17, 2005 | 11:43 AM
Default Re: who makes runners for custom itbs (H23vtecEG)
i already have the flange
just need runners for it...hit me with pricing for runners those who have them for sale..... compguy209@hotmail.com
its a steel flange so im pretty sure i need steel runners....unless you can weld aluminum to steel?
Old Mar 17, 2005 | 01:40 PM
743power's Avatar
wouldn't the thermal properties of a steel flange/runners be much less desirable for an intake manifold, than aluminum?
Old Mar 17, 2005 | 02:53 PM
SJcivic's Avatar
Default Re: who makes runners for custom itbs (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't the thermal properties of a steel flange/runners be much less desirable for an intake manifold, than aluminum? </TD></TR></TABLE>
:lightbulb:
Rich
Old Mar 17, 2005 | 03:17 PM
Default Re: who makes runners for custom itbs (SJcivic)
guess neither of you have seen these new fangled things that hondata makes that insulates the intake manifold from the head =P
Old Mar 18, 2005 | 06:08 AM
H23vtecEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">i already have the flange
its a steel flange so im pretty sure i need steel runners....unless you can weld aluminum to steel? </TD></TR></TABLE>
i make this in 6061 AL 1/2 thick...... steel aint gona do you any good. that was a waste of money
Old Mar 18, 2005 | 08:28 AM
weiRtech's Avatar
OG Fabricator
the phenolic gasket will definitely make a difference with heat transfer into the manifold from the head, but steel is gonna make the whole thing really heavy compared to aluminum and the hondata gasket won't make a lick of difference to the ambient air around the intake runners.
i make all my own flanges and do all my own welding. those weber runners are tig'd not mig'd. i haven't started making im mani flanges with the bosses. i don't intend to. they are kinda a pain to make- without the bosses is no problem though i can make those all day long. i will however be making complete manifolds hopefully by the end of the summer based loosly on the prototype below that i built. instead of the "box" pleunum i plan on going with a sheet aluminum contoured plenum instead. i also plan on doing some dyno testing before i start making them available.
Old Mar 18, 2005 | 10:12 AM
SJcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">guess neither of you have seen these new fangled things that hondata makes that insulates the intake manifold from the head =P</TD></TR></TABLE>
No gasket will sheild 100% of heat from the head, unless its magic. The heat transfer of aluminum is hugely greater than that of steel. Steel retains heat for MUCH longer periods of time. Ill go with what all the bigname companies have already R&D from the 1960's.
Rich
Old Mar 18, 2005 | 11:44 AM
Cyberdx16's Avatar
make your own runners!!! all u need is 1 1/2" piping and to get the oval shape pipe use a vice.
this is what i did
https://honda-tech.com/zerothread?id=1144101
Old Mar 26, 2005 | 06:13 AM
H23vtecEG's Avatar
Default Re: who makes runners for custom itbs (Cyberdx16)
this is my flange and runners
this is a set i made for DanishR
Old Mar 26, 2005 | 09:46 AM
Karterguy13's Avatar
I want to do a busa setup. Busa TB are hard to find though
Old Mar 26, 2005 | 11:54 AM
Default Re: who makes runners for custom itbs (Karterguy13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">I want to do a busa setup. Busa TB are hard to find though</TD></TR></TABLE>
since when&gt;? when i ordered mine off ebay there was 3 other sets for sale also
Old Mar 26, 2005 | 11:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG &raquo;</TD></TR><TR><TD CLASS="quote">this is my flange and runners
this is a set i made for DanishR</TD></TR></TABLE>
email sent...that basicly what i want except without the stepped up tube at the end welded on...i want one straight runner that mates up with the itb...one straight flush tube no step up tube welded on the end...that just looks bad
Old Mar 26, 2005 | 12:28 PM
RCautoworks's Avatar
i make this in 6061 AL 1/2 thick...... steel aint gona do you any good. that was a waste of money</TD></TR></TABLE>
Why is it a waste ? A steel flange with a heat gasket will be fine, the only reason you would want aluminum is if your gonna weld the itb's which I would not do anyways, because there so thin. You could well on steel runners on a steel intake flange, then use header wrap to insulate them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJcivic &raquo;</TD></TR><TR><TD CLASS="quote">
Rich</TD></TR></TABLE>
True but you can make steel be just as cool. If you wanted to you could ceramic the inside, they do this a lot on motorcycle exhaust piping, the pipe is cool to the touch 2 seconds after the engine is shut off. Yes big name companies use aluminum but when is the last time you have seeb big name companies weld itb's together like this, they cast the aluminum first.
Old Mar 27, 2005 | 07:50 AM
743power's Avatar
Default Re: who makes runners for custom itbs (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
True but you can make steel be just as cool. If you wanted to you could ceramic the inside, they do this a lot on motorcycle exhaust piping, the pipe is cool to the touch 2 seconds after the engine is shut off. Yes big name companies use aluminum but when is the last time you have seeb big name companies weld itb's together like this, they cast the aluminum first.</TD></TR></TABLE>
coating, wrapping, heat shield gaskets, etc, all things that aren't needed with aluminum.
Old Mar 27, 2005 | 09:01 AM
H23vtecEG's Avatar
coating, wrapping, heat shield gaskets, etc, all things that aren't needed with aluminum. </TD></TR></TABLE>
word yo. y bother spending all that time and money
Old Mar 27, 2005 | 09:04 AM
word yo. y bother spending all that time and money </TD></TR></TABLE>
Why bother ? Because you don't have a tig machine that can weld aluminum. I got price quotes to weld aluminum like that and they quoted me over $100
Old Mar 27, 2005 | 09:21 AM
H23vtecEG's Avatar
Why bother ? Because you don't have a tig machine that can weld aluminum. I got price quotes to weld aluminum like that and they quoted me over $100</TD></TR></TABLE>
you got to pay it if u wan it. 100 aint ****. im sure if he looks around localy he can find a welder that will do it cheap
Old Mar 27, 2005 | 12:37 PM
you got to pay it if u wan it. 100 aint ****. im sure if he looks around localy he can find a welder that will do it cheap</TD></TR></TABLE>
dont respond to emails?
Old Mar 27, 2005 | 01:45 PM
H23vtecEG's Avatar
dont respond to emails?</TD></TR></TABLE>
im sorry you never emailed me....... bmybmobile@yahoo.com thats my email
