oil leak!! need help!!
Old Mar 16, 2005 | 12:11 PM
Apocolipse269's Avatar
Default oil leak!! need help!!
ok, so i went to top off my oil before i change it this weekend, and like, when i drove my car i came back and there was a whole puddle of oil underneath. This wasnt there before i put new oil in it, and i didnt like hit anything. I think my stepdad told me the wrong weight to put in, he said 10w 30, and the air box says 5w 30. Could this have something to do with it? and if so is there a possibility of major damage to my engine? how do i fix this, ima do an oil change like NOW (as soon as i can get a ride to Autozone) please help!
Old Mar 16, 2005 | 12:14 PM
IHateJDM's Avatar
Default Re: oil leak!! need help!! (Apocolipse269)
You have to find the leak. The viscosity of the oil shouldn't matter.
Old Mar 16, 2005 | 12:17 PM
EJ1 wilcox's Avatar
Default Re: oil leak!! need help!! (93delslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo &raquo;</TD></TR><TR><TD CLASS="quote">You have to find the leak. The viscosity of the oil shouldn't matter. </TD></TR></TABLE>
Yeah, using a different weight oil wouldn't have caused the leak...LoL...
get under there and do some investigation! The first step is finding the source of the leak...
Old Mar 16, 2005 | 12:24 PM
HitEm'Up's Avatar
Just check the gaskets
Old Mar 16, 2005 | 12:46 PM
Default Re: oil leak!! need help!! (98JRSChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JRSChatch &raquo;</TD></TR><TR><TD CLASS="quote">Just check the gaskets </TD></TR></TABLE>
Easier said than done . Ima pull it up on some blocks now and check where its commin from. from what i have seen so far it looks to be near the oil filter
Old Mar 16, 2005 | 12:49 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 &raquo;</TD></TR><TR><TD CLASS="quote">Easier said than done . Ima pull it up on some blocks now and check where its commin from. from what i have seen so far it looks to be near the oil filter</TD></TR></TABLE>
Nice, tighten that sucker back up and call it a day
Old Mar 16, 2005 | 12:50 PM
Default Re: oil leak!! need help!! (EJ1 wilcox)
well i got new oil and a new filter, so ima further investigate when i put them on. First time i've ever done an oil change, so tell me if im correct ( i believe i am...) oil out, filter off, new fileter on, new oil in
basically right?
Old Mar 16, 2005 | 12:53 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 &raquo;</TD></TR><TR><TD CLASS="quote">well i got new oil and a new filter, so ima further investigate when i put them on. First time i've ever done an oil change, so tell me if im correct ( i believe i am...) oil out, filter off, new fileter on, new oil in
basically right?</TD></TR></TABLE>
Yep, it's pretty basic.
Old Mar 16, 2005 | 01:19 PM
komat's Avatar
dont forget to put some oil in the filter
also make sure the old filter gasket isnt stuck on the block if it is take it off or you will get major oil leak
Old Mar 16, 2005 | 01:20 PM
EJ1 wilcox's Avatar
Default Re: oil leak!! need help!! (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">dont forget to put some oil in the filter</TD></TR></TABLE>
And replace the crush washer...
Old Mar 16, 2005 | 01:24 PM
92eh3si's Avatar
one time i did an oil change on my friend's car and when I took the oil filter off,
the gasket on the oil filter was still attached to the block, of course i didn't know.
i put a new oil filter on wit another gasket without knowing, got it all done and started the car, oil all over the place
u might wanna check that since u said the leak was near the oil filter
Old Mar 16, 2005 | 02:11 PM
Default Re: oil leak!! need help!! (92eh3si)
ok, done the change, no filter gasket stuck, oil in the filter first, every thing so far so good. I looked more around and it seems that it was the oil filter that was the cause of the leak, of course i dont know why it would all of a sudden start leaking with out any physical damage or anything (it was perfectly fine untill this morning) I drove it around the block and its sittin in my drive way so i can monitor if it is still leaking
Old Mar 17, 2005 | 06:58 AM
ok, so i've been watchin my car closely since i changed the oil, and there appears to be no leaks any more ( i was scared this morning b/c there was oil in my parking spot at school, but its the same oil from yesterday )
I do however notice a weird smell, could this be attributed to previous driving w/ low oil? or could it be anotehr problem all together. My brake pads do need replacing so it could be that too. Just wanted to know, thanks for help guys
Old Mar 17, 2005 | 07:11 AM
ironlung78's Avatar
weird smell is probably coming from the oil that dripped onto your exhaust. as you drive it will eventually all burn off.
Old Mar 17, 2005 | 07:14 AM
Default Re: oil leak!! need help!! (sidesi)
ok, that makes some sense as there was oil driped on to my exaust. Thanks
Old Mar 17, 2005 | 07:19 AM
94sol_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eh3si &raquo;</TD></TR><TR><TD CLASS="quote">one time i did an oil change on my friend's car and when I took the oil filter off, the gasket on the oil filter was still attached to the block, of course i didn't know.
u might wanna check that since u said the leak was near the oil filter </TD></TR></TABLE>
same exact thing happened to me once...
something about this thread makes me laugh
AZNMOB
Jan 25, 2007 06:13 PM
Hiroshima_VTi-S
Aug 23, 2006 12:12 PM
OldSkoolEskimo
Jan 3, 2006 12:11 PM
kegard
32
May 30, 2005 12:12 AM
Steve26
Jul 29, 2004 05:09 PM
