Setting distributor timing back to stock, no timing gun ?
Old Mar 16, 2005 | 09:55 AM
X2BOARD's Avatar
Default Setting distributor timing back to stock, no timing gun ?
Lots of people have different views on it... but what's the proper procedure ?
My timing was advanced and I'm on a bad tank of gas and need to drop it down some, but I won't have access to a timing gun for a couple weeks.
Some ppl recommend doing while the car is running and the diagnostic jumper is shorted. So should I do it while running or not ? If not... why the jumper ?
Old Mar 16, 2005 | 10:44 AM
Honda Hick's Avatar
Default Re: Setting distributor timing back to stock, no timing gun ? (X2BOARD)
The proper procedure in the Honda manual says get the car up to operating temperature. Then while the car running jump the diagnostic plug with a wire. Then set the timing with a timing light and when it's done pull the wire out of the plug. I don't really know how you're going to set your timing without a light though. Maybe buy one and return it after you use it, heh.
Old Mar 16, 2005 | 10:50 AM
X2BOARD's Avatar
I have the stock setting marked on the distributor from when it was advanced.
Old Mar 16, 2005 | 10:55 AM
eK9aT10pSi's Avatar
Default Re: (X2BOARD)
turn the car off, loosen the 3 12mm bolts, match up the lines, then turn the car on
Old Mar 16, 2005 | 11:23 AM
X2BOARD's Avatar
Default Re: (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">turn the car off, loosen the 3 12mm bolts, match up the lines, then turn the car on</TD></TR></TABLE>
Umm... what about the diagnostic jumper ?
Old Mar 16, 2005 | 11:56 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Umm... what about the diagnostic jumper ?</TD></TR></TABLE>If you're not using a timing light, don't worry about that. All it does is tells the ecu NOT to make continuous little adjustments to the timing while it's running (while you're measuring it).
Old Mar 16, 2005 | 12:02 PM
X2BOARD's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If you're not using a timing light, don't worry about that. All it does is tells the ecu NOT to make continuous little adjustments to the timing while it's running (while you're measuring it).
OOohh... learned me something new !
Old Mar 16, 2005 | 12:08 PM
CNSK's Avatar
I tried shooting my timing gun to my crank pulley and i think my 2 white marks plus the red is gone.....I figure it was grease up so I cleaned it ....but still cant see ****....
Old Jul 2, 2005 | 07:42 PM
the.hamburglar's Avatar
Default Re: (CNSK)
yeah same with me, what should i do? there are no colors at all and i cant see any groovs
Old Jul 2, 2005 | 07:43 PM
98b18black's Avatar
Default Re: (hamburgler)
Which way do you move the dizzy to advance the timing? Towards the firewall, or towards the radiator support?
Old Jul 2, 2005 | 09:25 PM
rustyhatch's Avatar
Default Re: (95d15red)
autozone has a free rent a tool program. put down a deposit and if you return it, you get it back. its the greatest.
Old Jul 2, 2005 | 09:27 PM
Default Re: (rustyhatch)
towards the firewall advances the timing i just found out
allnaturalb16
21
Aug 14, 2007 08:57 PM
matbh22a
Jun 19, 2007 12:15 PM
53JDMDC2
Oct 1, 2004 10:27 PM
tianporn
Aug 1, 2004 12:20 AM
Tx92AccordExD
Jul 22, 2002 11:13 PM
