I did a search but nothing 4 pages for ticking alright i got a problem
Old Mar 16, 2005 | 08:19 AM
Jerms's Avatar
Default I did a search but nothing 4 pages for ticking alright i got a problem
okay yesterday i did a oil change topped it up and then i started it up and drove it to the gas station while i was driving it started making this tickign sound it would get louder when i was excellerate and i'm at idle its fine it does this when i'm parked and reving it no high at all.
i asked a guy at my work he came and heard my engine he says its my lifters but i donno ive never heard this noise before its coming from right beside the dizzy / cam angle sensor ( the engine is a Jdm dohc zc )
Modified by Jerms at 5:30 PM 3/16/2005
Old Mar 16, 2005 | 08:43 AM
Jerms's Avatar
Default Re: I did a search but nothing 4 pages for ticking alright i got a problem (Jerms)
BUmp help me out ppl i'm just gonna see re adjust the valves and see if thats the problem
Old Mar 16, 2005 | 10:00 AM
Jerms's Avatar
bump
Old Mar 16, 2005 | 10:02 AM
EP3_05's Avatar
Adjust the valves. My old jdm dohc zc was notorious for ticking valves. Even when they were properly adjusted the ticking was there albeit not as loud. Also OBD0 injectors are known to be loud as well. I know my b16a injectors are pretty loud under operation.
Old Mar 16, 2005 | 10:17 AM
Jerms's Avatar
Default Re: I did a search but nothing 4 pages for ticking alright i got a problem (91civic)
its wierd though it only ticks when i;m reving it or driving it
Old Mar 16, 2005 | 10:23 AM
civicflow's Avatar
Could it be coming from the dizzy? My dizzy started making skraping and ticking noises before it went out.
Old Mar 16, 2005 | 10:24 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerms &raquo;</TD></TR><TR><TD CLASS="quote">its wierd though it only ticks when i;m reving it or driving it </TD></TR></TABLE>
Ok i misread you original post. So it only does it while driving? Is it a ticking, scraping, squeeling?
Keebler's Avatar
Default Re: I did a search but nothing 4 pages for ticking alright i got a problem (civicflow)
Could also be arcing plug wires/coil.
Old Mar 16, 2005 | 10:26 AM
ELAMINT5's Avatar
sounds like a lifter, adjust the valves. and if they does not fix it then we can move further. until you try and fix that, that is going to be the main response you get.
GOOD LUCK
Old Mar 16, 2005 | 10:48 AM
Jerms's Avatar
Default Re: I did a search but nothing 4 pages for ticking alright i got a problem (ELAMINT5)
alright thanks for all your help guys i'll do that
sound slike like a ticking sound when i rev it gets louder
Old Mar 16, 2005 | 11:13 AM
Keebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerms &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks for all your help guys i'll do that
sound slike like a ticking sound when i rev it gets louder</TD></TR></TABLE>
Definately check your lifters (valve lash) first, then move on from there
Old Mar 18, 2005 | 12:11 AM
Jerms's Avatar
Default Re: I did a search but nothing 4 pages for ticking alright i got a problem (Keebler)
i found out the problem nothign do with the engine it was the header i installed the y pipe gasket wasn;t tightened enough so the valves were echo'ing off the engine
Old Mar 18, 2005 | 12:27 AM
kingkong's Avatar
that was pathetic
Old Mar 18, 2005 | 06:04 AM
PaImportTuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jerms &raquo;</TD></TR><TR><TD CLASS="quote">i found out the problem nothign do with the engine it was the header i installed the y pipe gasket wasn;t tightened enough so the valves were echo'ing off the engine</TD></TR></TABLE>
rofl i bet he was scarred to ****.
MG6
Jun 5, 2009 01:50 PM
Robstunner4
Mar 12, 2006 03:45 PM
wragen22
Apr 8, 2005 11:44 AM
bcphatchback
13
Jan 6, 2005 09:38 PM
dohczc
Jan 24, 2002 01:08 PM
