do i need to balance these?
Old Jan 23, 2002 | 08:25 PM
max's Avatar
max
Default do i need to balance these?
for my ls/vtec engine i can get a set of LS rods w/ usdm type-r pistons (p73 i think) already on them. assuming i have no imperfections in the crank/cylinder-walls and i get new rings and bearings, i would just have to balance the new pistons. now, do i just get them balanced on the crank and then just use it in the engine. or do i need to balance the whole engine together?
also, if anyone knows places in CT that work w/ hondas and their prices for this kinda job?
Old Jan 23, 2002 | 10:37 PM
FSTASNTZ's Avatar
Default Re: do i need to balance these? (max)
All of the rotational assembly together, Flywheel, pistons, crank, rods, crank pulley...
Jason
Old Jan 23, 2002 | 11:36 PM
max's Avatar
max
Default Re: do i need to balance these? (FSTASNTZ)
ok, then how about this next scenario. i also have a set of 4 LS rods w/ ls pistons, but one rod is bent. so i was gonna go to acura and buy the same number rod. if i get that same number rod and get it pressed on the piston, do i need to balance then? i heard honda does it all from the factory, that's why they have those numbers on parts. so if i get the same weight rods, it will be a perfect match?
915hondajunkee
Nov 24, 2008 08:37 AM
Baggy Spandex
Nov 1, 2005 12:02 PM
vtec_yosh
Jun 29, 2004 02:32 AM
RTW DC2R
Apr 24, 2004 10:39 AM
fox297
Aug 14, 2003 06:30 PM
