94-97 Accord mirror question
Old Mar 15, 2005 | 10:36 PM
fongph's Avatar
* B A N N E D *
Default 94-97 Accord mirror question
I just got hit-and-run on my driver side mirror on my 1994 Accord EX 2dr. I searched on ebay and only 4dr mirrors are available. I know 2dr mirrors and 4dr mirrors have different part number but I thought their appearance just look the same. Has anybody tried to put a 4dr mirror on 2dr? Do you know if the 4dr mirror will fit 2dr with very little modifications?
Thanks
Old Mar 16, 2005 | 01:50 AM
fongph's Avatar
* B A N N E D *
Default Re: 94-97 Accord mirror question (fongph)
bump
Old Mar 16, 2005 | 04:05 AM
kniob's Avatar
the mirrors are the same.
Old Mar 16, 2005 | 08:55 PM
fongph's Avatar
* B A N N E D *
Default Re: 94-97 Accord mirror question (kniob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kniob &raquo;</TD></TR><TR><TD CLASS="quote">the mirrors are the same. </TD></TR></TABLE>
Are you really sure about this? I don't want to order the useless part.. also I am confused about them having different part numbers if they are identical.
Thank you so much
Old Mar 16, 2005 | 09:39 PM
91wagon's Avatar
Yes, the mirrors are the same.
Old Mar 16, 2005 | 10:01 PM
z168's Avatar
Default Re: 94-97 Accord mirror question (91wagon)
mirror itself and housing the same for 4dr and 2dr. the stem is whats different vis-a-vis the bolt pattern to the door
Old Mar 16, 2005 | 11:24 PM
fongph's Avatar
* B A N N E D *
Default Re: 94-97 Accord mirror question (z168)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z168 &raquo;</TD></TR><TR><TD CLASS="quote">mirror itself and housing the same for 4dr and 2dr. the stem is whats different vis-a-vis the bolt pattern to the door
So I can't bolt the 4dr mirror to the 2dr chassis without modification since they have different bolt pattern?
Thanks
Old Mar 17, 2005 | 01:34 AM
JonnySBeee...'s Avatar
THEY ARE THE SAME!
Old Mar 17, 2005 | 11:45 AM
z168's Avatar
Default Re: 94-97 Accord mirror question (jonny05)
ANS : Again if youre talking about removing the whole sidemirror assy from a 4door then transfer to a 2dr it wont fit. you can but you need to drill/revise the holes onto the door
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonny05 &raquo;</TD></TR><TR><TD CLASS="quote">THEY ARE THE SAME!</TD></TR></TABLE>
learn from my experience. I bought a pair of 4dr sidemirror assy they wont fit unto a 2dr. i had to take apart the mirror assy and transfer the 2dr stem unto the 4dr mirror housing
Old Mar 17, 2005 | 12:06 PM
devilpuppy's Avatar
yea..i have a coupe and am looking for the driver mirror
i called honda to ask if the sedan mirror will fit....the asnwer is NO
if u look at the bezel of the mirror (the triangle part) they should be different sizes
Old Mar 17, 2005 | 12:19 PM
z168's Avatar
Default Re: 94-97 Accord mirror question (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">yea..i have a coupe and am looking for the driver mirror
if u look at the bezel of the mirror (the triangle part) they should be different sizes</TD></TR></TABLE>
you can make it fit (if your desperate) but you need to enlarge the 2 holes and make a completely new hole for the 3rd bolt
thugzpassionstp7
Feb 26, 2007 06:59 AM
Carloscda37
Dec 24, 2005 06:21 PM
FrekSdn
Jan 22, 2005 06:43 PM
integlude
Jan 15, 2004 12:11 PM
HRC51
Mar 10, 2002 08:53 AM
