ps pump doesn't fit my b18b swap
the power steering pump i ordered form HMO doesn't fit my power steering line. i have a 00 ex and a 99 b18b. the pump i got from HMO bolts up and lines up and everything, but when I tried to put the ps hose back on the pump, the hose fitting was too big and wouldn't go in. also looks like the bolt holes don't line up. i thought this was a direct fit? is it maybe cause the pump is from a jdm motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote"> the pump i got from HMO bolts up and lines up and everything, </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote"> also looks like the bolt holes don't line up.</TD></TR></TABLE>
Maybe I'm just missing something, but I'm lost.
i meant the brackets and all bolt up and the ps belt is on fine. but when i got to put the hose on, the metal fitting that goes INTO the pump is too big on the civic side. the integra pump's hole is too small. and the bolts that hold the hose in are a little offset
Tong.Y
Apr 17, 2011 12:06 PM
motormanSR
Oct 29, 2004 04:34 AM
