pr3 pcm with boost possible wit turboEDIT?
Old Mar 15, 2005 | 07:15 PM
honda06si's Avatar
Default pr3 pcm with boost possible wit turboEDIT?
ok ive been reading about TE for a coulple weeks now.. ive played around with the base pr3 map on the software but it only goes to 7400 rpms...so i asked people about this and people say oh just keep the pr3 and you can set the rev limits higher (which i tried) and other people tell me the pr3 will not run a b16 with boost
oh i will be boosting 10psi and still wanting to rev to 8200
Old Mar 15, 2005 | 07:57 PM
honda06si's Avatar
Default Re: pr3 pcm with boost possible wit turboEDIT? (honda90si)
Old Mar 15, 2005 | 08:32 PM
honda06si's Avatar
SIMPLE QUESTION PLESE ANSWER?
can i run turboedit on a pr3 with boost?
Old Mar 15, 2005 | 09:02 PM
Tchleung's Avatar
NO, There is no real free editing programs that really support OBD0 VTEC right now.
Old Mar 15, 2005 | 09:06 PM
honda06si's Avatar
Default Re: pr3 pcm with boost possible wit turboEDIT? (Tchleung)
so why is it ive seen turbo'd b16 obd0 with turboedit as their EMS???
Old Mar 16, 2005 | 05:29 AM
Tchleung's Avatar
alot of ppl use a PR4 etc. You can't open PR3 in turboedit. when you do. it mixes it up and only opens 1 table for fuel and ign when there should be 2 for each. Alot of ppl use the Ps9 etc as well and do the 1 wire vtec witht he tranny wire etc
Old Mar 16, 2005 | 06:07 AM
splitime's Avatar
Default Re: (Tchleung)
PM6s also have a 1wire vtec option.. if you don't want/care about your AC.
http://www.pgmfi.org and look around for more info.
Old Mar 17, 2005 | 10:24 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">alot of ppl use a PR4 etc. You can't open PR3 in turboedit. when you do. it mixes it up and only opens 1 table for fuel and ign when there should be 2 for each. Alot of ppl use the Ps9 etc as well and do the 1 wire vtec witht he tranny wire etc</TD></TR></TABLE>
You can open a stock PR3 BIN file in TurboEdit...just not one with boost. You can adjust rev limits and VTEC points in the stock file as well.
Old Mar 17, 2005 | 10:25 AM
quicksol95's Avatar
Default Re: (xenocron)
i believe zdyne will work for you
Old Mar 17, 2005 | 11:25 AM
xenocron's Avatar
Default Re: (slow90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow90hatch &raquo;</TD></TR><TR><TD CLASS="quote">i believe zdyne will work for you</TD></TR></TABLE>
How is ZDYNE any different than the TurboEdit/PGMFI 1-Wire VTEC code. If anything he would be better off with TurboEdit because he can datalog...no datalogging with ZDYNE
Old Mar 17, 2005 | 12:07 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">
How is ZDYNE any different than the TurboEdit/PGMFI 1-Wire VTEC code. If anything he would be better off with TurboEdit because he can datalog...no datalogging with ZDYNE </TD></TR></TABLE>
exactly what I was thinking. not to mention it is free.
Old Mar 17, 2005 | 01:05 PM
honda06si's Avatar
Default Re: (93turbo16)
im prolly wrong but isnt zdyne for obd1??
Old Mar 17, 2005 | 01:49 PM
Sonny's Avatar
Default Re: (honda90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">im prolly wrong but isnt zdyne for obd1??</TD></TR></TABLE>
Nope. It's for OBD0.
Sonny
Rukusmasta2
Engine Management and Tuning
May 8, 2008 07:18 AM
jdmsijdm
Jan 4, 2005 06:50 PM
crx12
Jun 16, 2004 03:13 PM
mattcalica
Aug 23, 2003 04:38 PM
skud_dusty
Mar 15, 2003 08:27 PM
