code 21
Old Mar 15, 2005 | 06:42 PM
JDM JEFFREY's Avatar
Default code 21
my car is throwing a code 21 but all my vtec wires are all wired right
could it be my vtec solenoid????
Old Mar 15, 2005 | 07:44 PM
Default Re: code 21 (JDM JEFFREY)
bump
Old Mar 15, 2005 | 09:21 PM
ttt
Old Mar 15, 2005 | 10:03 PM
gitwidit's Avatar
I'm pretty sure that the vtec solenoid/valve needs oil pressure (spool) to activate. The valve is bad or you have low oil pressure.
Old Mar 16, 2005 | 04:28 AM
JimBlake's Avatar
Default Re: code 21 (GITWIDIT)
If you're sure the wires are OK, then it CAN be a bad solenoid valve. Remember, it's only got one wire, it's grounded thru the head. If your engine grounds aren't good, that can do it too.
djden253
Oct 31, 2005 02:50 AM
tachyteg
Aug 29, 2005 09:20 PM
davejj40
Aug 30, 2004 01:29 PM
BobGnarly
May 23, 2004 05:28 PM
