ground control coilovers....are these for EK?
Old Mar 15, 2005 | 05:02 PM
Unjockable's Avatar
New User
Default ground control coilovers....are these for EK?
can someone check the part number for me?
Old Mar 15, 2005 | 05:25 PM
92b16vx's Avatar
That's an Eibach part number, not a ground control. You don't have to worry about the spring, you need to worry about the shock and how it mounts to the LCA. But from what I have seen, a lot of manufacturers, send out EG shocks, since they have a wider mounting fork that an EK, and you just use washers on an EK to fill the space.
Old Mar 15, 2005 | 05:27 PM
Unjockable's Avatar
New User
Default Re: (92b16vx)
i know the spring doesn't matter. it's just better if i knew what spring rate it's for before buying.
Old Mar 15, 2005 | 05:29 PM
92b16vx's Avatar
Now see, you mentioned nothing about rates in your first post. Anyway, GC or Eiback should have a guide on thier sites, probably a PDF form.
Old Mar 15, 2005 | 05:35 PM
Unjockable's Avatar
New User
yeah, my bad.
i checked both their sites but found nothing. that's why i posted on here to see if anyone knows. i must be blind.
Old Mar 16, 2005 | 04:24 AM
EE_Chris's Avatar
Default Re: (Unjockable)
"How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by". "
So it looks like you have a 700mm long spring, 250mm in diameter with a spring rate of 360lb/in.
That info was taken from HERE.
meandyanyan
Canada (Sales)
Aug 5, 2013 01:00 PM
guedo148
Suspension & Brakes
Apr 11, 2007 04:03 PM
deviant1
May 1, 2004 03:33 PM
