CTR pistons in a b18c5
Old Mar 15, 2005 | 04:57 PM
pacifico's Avatar
Default CTR pistons in a b18c5
Ive already searched and some people say its ok and some dont. Anyone actually have this done on theyre daily driver? Stock everything else.
thanks for any info in advance
Old Mar 15, 2005 | 07:23 PM
mmuller's Avatar
Mad Scientist
Default Re: CTR pistons in a b18c5 (pacifico)
headaches..
worse combustion quality.
unneeded super high compression( for a street car at least)
Old Mar 15, 2005 | 09:14 PM
neeks's Avatar
Default Re: CTR pistons in a b18c5 (mmuller)
i have ctr pistons in my gsr engine and let me tell you......ITS A PAIN IN THE ***
you gotta get your shortblock honed at the shop $80, new piston rings ~$160 oem gsr rings, installation (if you duno how to do it yourself) $200 bucks, not to mention if you pull out your head from your block you have to get a new head gasket $100...
so your ctr pistons (i duno how much they are..200?) plus 280 for labor for hone and install, 160 for rings, 100 for gasket sooooo
750 bucks? for 1 or 2 points more compression? plus you know how much it is if you have to change your rings in the future at the shop???????? $800 FREAKIN BUCKS (NOT INCLUDING THE RINGS!)
if youre an na junkie do it if you love it that much but if i were you id do yourself a favor..buy your loved ones some presents and flip your car off..
im going to run 13:1 compression btw...not very safe...
Modified by neeks at 12:49 AM 3/16/2005
Old Mar 15, 2005 | 09:54 PM
Kendall's Avatar
It can be a potent setup, but PCT's in a P72 block with either VTEC head yields stupid high compression that, without tuning, can cause detonation on 93 octane pump gas.
If you're looking for more compression, consider a set of high compression valves and a thinner headgasket.
Old Mar 16, 2005 | 09:47 AM
pacifico's Avatar
Default Re: (Kendall)
i am doing a rebuild anyway so I thought I might try this.......guess not
skata89
Apr 24, 2008 11:06 AM
Jap_Spec_Imports
Apr 11, 2008 10:50 AM
SexyHatchie
Sep 24, 2007 12:13 PM
10000rpm
Sep 20, 2004 02:27 PM
Teepo
Nov 7, 2002 08:28 PM
